Old 03-24-2011, 03:07 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
auto seat belt stuck
My drivers seat belt is stuck in the forward position. It just stopped working out of nowhere. Can anybody tell me what would cause this and how to fix it.
I has teh FWD LS-L
Old 03-24-2011, 04:53 PM
Old Fogey
Re: auto seat belt stuck
If it is only the driver side that is inop it could be the door latch switch on that side door is stuck "ON" or a short in that side wiring. If the door is closed, key in ignition but left in "OFF" position the key warning chime should be operating if the door latch switch is stuck "OFF or open circuit in wiring"). I see you're in Fla, so frozen latch or switch is unlikely. but could be wet or shorted.
If both sides are inop check fuse No22 (15A) that powers the Passive belt control unit. Are you getting any display on the dash indicating a seat-belt fault (flashing seat belt) ?
Gotta warn you, the Service Manual section "Troubleshooting{Automatic Shoulder Belt} is 32 pages if a self-diagnosis fault is displayed, including instructions on use of the diagnostic plug located near the fuse-box in left footwell to trigger display of trouble code (only one fault is stored at one time).
Be sure to check here: http://www.subaru-svx.net/forum/showthread.php?t=53940 for instructions on it's use.
Glenn
Old 03-24-2011, 04:55 PM
Look in your center console, there should be an allen wrench type thing under the bottom of it. Take off the back seat bottom and use the allen wrench to crank the seatbelt back to the rear position by putting it through a hole under the driver's side armrest that's exposed when the back seat bottom is removed. Odds are either the seatbelt motor or controller are toast. I have both (two controllers actually) if you need them. Controller is the likely culprit if the other side also doesn't work.
Old 03-24-2011, 06:53 PM
92_LSL's Avatar
The seat belt has done this several times before but has always started working again shortly after. The passenger side works fine but the driver's side doesn't work at all even with the key in the ''on'' position.
I has teh FWD LS-L
Old 03-24-2011, 08:03 PM
Jonnycash's Avatar
Jonnycash Jonnycash is offline
Mine did exactly what you described... it was the seat belt computer in the trunk. I had a spare, so I switched it just for giggles and it fixed it.
Giving money and power to government is like giving whiskey and car keys to teenage boys. – P.J. O'Rourke
Old 03-25-2011, 12:17 PM
torxxx torxxx is offline
you guys got lucky if its just a computer issue. normally these auto seat belts suffer from cable snapping or the cable fraying and jamming the motor.
My drivers side luckily is stuck back so I just leave it plugged in adn flip it over my shoulder. I'd really like to get ride of the auto belts... the 3 years subaru used them was more than enuff time to frustrate any mechanic. I've changed soooo many of those auto assemblies
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 03-25-2011, 02:19 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
okay. i was messing around with my seat belt, and i put a kleenex (don't ask why) in the part where it rests so it couldn't go down all the way. it seemed to lock, and when i opened the door, it opened right up! i put a little piece of soft rubber in there, and it goes into the rubber and stays in place. it feels the same as if it were all the way down. now. will this break if i get into a wreck because it's not all the way down?
also i somehow completely drained my battery by fiddling with the seatbelt for about 20 minutes. someone needs a trip to autozone...
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 03-25-2011, 02:38 PM
Maybe, actually. It depends on far it still has to go? Like a couple mm, probably ok, but a cm or more, I would try a different fix. The track where the seatbelt catch stops in the rear position is designed to sort of hook to it if there's an accident, the rest of the track isn't.
Old 03-25-2011, 03:22 PM
B 4 You's Avatar
#lolsvx
it's not much of a distance, but i don't want to mess with it.. because there is a big metal bar that the seatbelt latches to. i think in a fast wreck it would rip right out, which isn't worth having unsticky seatbelts. the WD40 seemed to help a little bit. once the warm weather hits i think it will be even better. i think something is bent.. oh well. it's not bothering me quite enough to spend money on it. yet.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 03-25-2011, 04:51 PM
92_LSL's Avatar
Well today I cranked the belt back, which is a major pita. Once I turned the car on and shut the door and opened it the Damn belt went back and stayed there.
I has teh FWD LS-L
Old 03-25-2011, 05:50 PM
If you unplug the seatbelt motor on that side ( The plug is near where the hole to crank it back is, but I forget exactly where), then it won't go forward anymore. Also if you unplug the seatbelt controller which resides in the ceiling of the trunk.
I also vaguely remember some way of hooking up the rear window switch to the seatbelt motor to control it manually, but you'd have to search for the thread. Could be a way to test if the motor or controller is bad.
Old 03-25-2011, 09:55 PM
A while back someone found out what the intermitent seat belt fix was. I don't remember who it was, but maybe someone else does. It would be good to find it and I will get it into the How-To Docs.
Old 03-26-2011, 11:29 AM
dcarrb dcarrb is offline
Does the "dome" light work properly? If not, it could be the door latch switch. Mine occasionally—well, usually—acts up, but fiddling with the door lock button does the trick.
dcb
Old 03-27-2011, 12:17 AM
B 4 You's Avatar
#lolsvx
do you mean the light that comes on when i open the door? yes, it works fine every time. i don't think it's the door latch because it starts to move along the track, but gets stuck after an inch.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 03-27-2011, 04:06 PM
92_LSL's Avatar
Yeah my dome light works perfectly fine. The thing I don't get is when I crank the belt back manually then shut and open the door the belt goes forward but doesn't go back.
I has teh FWD LS-L
