Old 03-19-2011, 06:03 PM
httrdd httrdd is offline
Now I see where the exhaust leak was from
These are the two pictures of the two pipes that come into a Y.
Not even sure what to do. I need a new pipe, but for now I am going to sleeve a pipe in there. Why replace only one??? Damn you previous owner!
Old 03-20-2011, 05:44 AM
Manarius's Avatar
Manarius Manarius is offline
Re: Now I see where the exhaust leak was from
I feel like you have been presented with a perfect opportunity to put straight pipes on your car.
Or at least to replace that silly combine/converter.
-Jason
-Obi Wan Kenobi
Old 03-20-2011, 05:42 PM
Actually when I get the right setup I have all the flanges and pipes to build long tubes.
Old 03-24-2011, 09:45 AM
torxxx torxxx is offline
wow I've never seen a subaru exhaust component rot like that, specially that close to the engine (source of heat). You must be in the North East US where they salt the roads?
I guess since we are on the subject of that part of the exhaust, what style of gasket/seal is used at the joint? or is it simply the sleeve that seals joint?
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 03-24-2011, 01:56 PM
Donut gasket not sure of the part number.
