Old 02-09-2011, 04:04 PM
rj7630 rj7630 is offline
Transmission speed sensor reinstall question
I pulled the transmission speed sensor out of the transmisson to check it and need to install it. I found when I removed it that there was a convex metal washer that rides on a shoulder just above the transmission drive shaft. When I pulled the washer out I did not notice if the curve was up or down. Anyone done this before?
Also, lining up the tab on the sensor to the groove on the transmisson shaft looks like it will be trouble. Any helpful hints for this?
Thanks.
Old 02-10-2011, 05:36 AM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Transmission speed sensor reinstall question
The tab should line up on it's own as you spin the sensor in. The curve should face away from the sensor. The rubber part of the washer should go against the sensor.
Wanted: Steering Wheel
Old 02-10-2011, 06:24 PM
Thank you very much. This will make reinstall much easier than I was going to try.
