Old 01-09-2011, 02:44 PM
Gamesy's Avatar
Gamesy Gamesy is offline
stator shaft removal
i'm trying to remove the stator shaft off an svx transmission i have laying around for a member on the forum.
i was wondering what the easiest way to remove it, is there a c-clip or do i have to take the front diff off?
Old 01-10-2011, 11:08 AM
Gamesy's Avatar
Re: stator shaft removal
can anyone help shed some light on this so i can get the part for a member so he can get his car running?
Old 01-10-2011, 09:06 PM
Gamesy's Avatar
i got the front diff off and am working on taking the pump off are there any hidden nuts or bolts that keep it on? i took off whatever i could find but its still stuck on
Old 01-13-2011, 02:21 PM
Gamesy's Avatar
how to take it off
take off front diff
take off rear diff
remove nut off power transfer shaft that runs from the back to the front ( the nut is NOT reverse threaded)
once nut is off you can pull out the shaft and the pump will come off and there are just a few 12mm bolts that hold it in plate
