Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 07-07-2009, 06:29 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: 06-07 WRX 4 pot brakes... FIT!
Excellent work so far on this, I hope a rotor can be sourced. How much did those brakes cost you?
Old 07-07-2009, 12:48 PM
BoxerFanatic's Avatar
Originally Posted by SilverSpear View Post
Victor can you post the ones of the Subaru BAJA?
Doesn't baja have 5x100 bolt pattern?
The Maxima ones look decent, but the rotor hat height doesn't look the same, which will likely make it not fit.
320mm diameter and 24-25mm thickness, with the same hat dimensions (height, bolt pattern) as SVX would be something to look for.
The increase in diameter, and decrease in thickness would probably more than offset each other, in terms of thermal mass of the disc itself.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 07-07-2009, 03:33 PM
the_paynter the_paynter is offline
Yes the Baja is 5x100, it is based off the Legacy/outback.
Im going to give the maxima disc a try... if it doesnt fit, i will just return it. The difference in the hat makes it look like its not going to work though... dang
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 07-07-2009, 03:42 PM
The disc heights are approx the same as the SVX. The only difference are in the bolt patterns and the thickness...
Wonder how do aftermarket BBK for Bajas look like?
Old 07-07-2009, 03:52 PM
alltrac alltrac is offline
Baja turbo
Baja non turbo
Victor
Old 07-07-2009, 03:54 PM
they're 5x100- wont work
Old 07-07-2009, 03:59 PM
But when you order aftermarket BBK for BAJA, the thickness comes minimum at 30mm and the hub is interchangeable, so you get the 5x114.3 instead...
I think Wilwood BBK is a nice affordable choice...
Old 07-07-2009, 04:05 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Just match up a Willwood or Coleman rotor ring to a billet hat from wilwood and you'll have your rotors.
I can do that for you easy as I have teh 2009 wilwood catalog sitting here in front of me. All I need from you is the rotor offset that's required, the rest of the specs were listed in the previous posts above. Measure the offset from the INSIDE surface of the rotor where it meets the hub to the rear face of the rotors.
Also, what's the hubcentric diameter on these cars?
Old 07-07-2009, 04:13 PM
58mm
Old 07-07-2009, 04:42 PM
I was just ask to post the specs I could care less if they are 5x100
Victor
Old 07-07-2009, 08:50 PM
If someone got him this information that would be awesome, I cant get at that until the weekend as im no wheres near a jack/tools while during the week but i can make a run to toronto on the weekend and do it
Old 07-07-2009, 09:09 PM
siceclipse's Avatar
siceclipse siceclipse is offline
DSM wheels are 5x114.3
i dont know the size of the disks so if you can find that out...
good luck
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 07-07-2009, 09:25 PM
I know the Evo IX is to big... ill check out a 99 GSX though
EDIT:
I checked it out... says an eclipse front rotor is 10.83", way to small..POWER SLOT makes a big brake rotor replacement for it thought that is 12.5", this is 317.5mm which is good.. as for width and hat size.. not sure yet
good luck
Old 07-07-2009, 09:35 PM
2009 Acura TL uses a 5x114.3 bolt pattern in their 3.5L model.
The rotor size is 12.6"x1.1" ooooorrrrrr 320mm x 28mm.......
This might work... but 2 CM increase might be large. Doing the math though thats only 1cm added all the way around
Hat height anyone?
Old 07-14-2009, 09:38 AM
sicksubie's Avatar
Can someone please go through the DBA catalogue already? Did you find anything BoxerSix?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
