Old 12-12-2008, 12:42 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Leaking Coolant
Hi all
I just picked up my SVX from getting a new aluminium radiator and transmission cooler. NOW, it is dribbling coolant out from under the engine!!! OMFG!!!
Now what??
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 12-12-2008, 02:31 AM
McTaff's Avatar
McTaff McTaff is offline
Mr Soob
Re: Leaking Coolant
Take it directly back and tell them to fix it. Likely that it isn't fitted correctly somehow.
Any mechanic that causes issues, should fix them free of charge. Take a couple photographs beforehand if practicable, if you can find the leak.
'07 Outback (Legacy) Pearl White > 3.0R Premium, stock (50,000km, Wifes daily driver. Owned from new) Not For Sale
'92 SVX Black on Pearl White > 6spd, DCCD on the way. (260,000km, My daily driver, 2 previous owners) Not For Sale
'93 SVX Black on Charcoal > Aftermarket rims.(250,000 km, Dad's daily driver, unknown owners) Not For Sale
'93 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (55,000km, 1 previous owner) Not For Sale
'92 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (144,000km, 2 previous owners) Not For Sale
Wife, Red Hot when riled > Treated like a princess. Minister For Finance, Domestic Affairs and Diplomatic Relations. Definitely Not For Sale
My Wanted List: http://www.subaru-svx.net/forum/show...178#post632178
Old 12-12-2008, 06:55 PM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
Re: Leaking Coolant
You should be aware that 2 coolant drain plugs are located on the bottom of the engine towards the front, one on each side of the oil pan.
It is possible that when the radiator was fitted, the old coolant was drained, and these plugs were removed, but were not correctly refitted.
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 12-12-2008, 08:21 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Leaking Coolant
Underneath the engine implies the water pump is going out s. Check and make sure they tightened the hoses good.
Old 12-12-2008, 08:47 PM
Re: Leaking Coolant
AND make sure that the overflow tube is pushed all of the way over the hexagonal part of the radiator neck overflow tube.
Old 12-12-2008, 11:24 PM
BRADY's Avatar
SVX Addict
Thumbs up Re: Leaking Coolant
Thanks guys.
I just purchased a new water pump for $85. My car has been sitting for a LONG time.
I will check what you have said while installing new pump.
Cheers!
Old 12-13-2008, 06:18 AM
legacyau legacyau is offline
Re: Leaking Coolant
Originally Posted by BRADY View Post
Thanks guys.
Cheers!
it might pay to do the timing belt while you're in there thats if your milage is correct in your sig
cam
Old 12-13-2008, 06:38 AM
BRADY's Avatar
SVX Addict
Re: Leaking Coolant
Hi Cam,
Yeah, my cousin/mechanic said the same thing about the timing belt. He also wants to do the cam seals. Are these around in Sydney area? Thanks.
Old 12-14-2008, 11:14 PM
BRADY's Avatar
SVX Addict
Re: Leaking Coolant
OK.
I have bought a water pump - $80 Autopro.
I have new cam seals etc $34 Hunter Subaru
AND the TIMING BELT - $165 Hunter Subaru (couldn't locate aftermarket type)
Fitting it this week.
I didn't get new sprockets though. Hope they are ok.
Cheers.
Old 12-14-2008, 11:53 PM
Rebuilding
Re: Leaking Coolant
Idle pullys should be okay. I have had apprently two sets go out on my car. One before I bought it (evidence were the marks on the cover) and once while I owned it. Also you'll know when one of them are on the way out when you here a metal on metal grinding coming from the middle of the front of the engine. Plus in good light you can actually see the medal shavings in the air.
Old 12-15-2008, 03:31 AM
BRADY's Avatar
SVX Addict
Re: Leaking Coolant
I have the new aluminium radiator out, and the front of the engine off to replace timing belt.
I have found there is an oil leak from the right cam seal.
Old 12-15-2008, 05:15 AM
Re: Leaking Coolant
you can get the seals separately if you can get the old one out and get the part number or do a search for the right part number any bearing place/repco should have one i have some seals spare from a turbo liberty but i dont know if they interchange. At least its not critical with these engines if the timing belt breaks, aside from the inconvenience check your bearings if theyre quiet your good
cam
ps i know your pain ive just had to fix both of my libertys that had cooling problems one of them being a water pump, where'd you get yours from? any chance you can get a pic of the new or old pump?
Old 12-15-2008, 05:19 AM
BRADY's Avatar
SVX Addict
Re: Leaking Coolant
ps i know your pain ive just had to fix both of my libertys that had cooling problems one of them being a water pump, where'd you get yours from? any chance you can get a pic of the new or old pump?[/QUOTE]
It turns out that the water pump I bought is for the 2.5 EJ25, Goddammit!
I will go back tomorrow ans see if they have the correct one. Then, I will post photos etc.
Old 12-15-2008, 08:21 PM
BRADY's Avatar
SVX Addict
Re: Leaking Coolant
I ended up ordering the water pump from Subaru. The non genuine one was iffy and the same price. $130 AU
I picked up my timing belt and various seals from Subaru too. At least they have HEARD of the SVX, unlike the AutoPro store! "VRX, WSX, SV What?"
Stay tuned - almost drivable!
Old 12-21-2008, 03:31 PM
Re: Leaking Coolant
So by the lack of additions to the thread i'm thinking you got it going and are driving the wheels of it ?
