Old 12-09-2007, 07:40 PM
reptar_head's Avatar
reptar_head reptar_head is offline
Wheel and tire experts I need opinions on 19"s
Ok, here's my situation. I have my heart set on some wheels that have been discontinued and I can't find many of them left. The only 2 sets I can find on ebay in our bolt pattern are a 19" by 9" wide with a 40mm offset, and a 19" by 8" wide with a 30mm offset. So is there any chance either of these will fit? I'd like to lower the car at some point as well, so I need to take that into consideration. I really wanted 18"s but like I said they don't make them anymore and I simply can't find them. 17"s look too small, so I don't want them. 19"s are ok, it's just the width issue I'm worried about. So, has anyone run either of those sizes, and if so with what size tires?
'95 SVX
'87 Dakota
'84 CJ-7
'06 CBR 600 F4i
'95 Katana 600
Old 12-09-2007, 07:51 PM
Well the 19x9" 40mm offset would be the closest fit, but probably wouldn't work. Buy them and try them. If they aare out of production and sought after then you should be able to re-sell them to get your money back.
A thought; if you go to coil overs you would be ussing a smaller spring diameter and gain some room on the inside of the chassis, but may still have issues ww/ clearance on things up front wwhen turning at full lock.
blk 92' LSL w/ average mods
Old 12-09-2007, 08:00 PM
The tire size I would recommend for 19's is 255/30/19. (it's basically the only size that exists for 19's that wil retain the stock tire diameter). Tirerack.com lists 9 tires in this size.
30mm offset will not work, no chance. You may be able to get the 40mm offset one to work, but you will most likely have to get the fenders rolled. There are a few members running 255 width tires on 8" wide rims, but the offset on those is ~48-50mm, and that's pretty tight. With the 40mm you'll be moving the outter edge of the tire a full 3cm outward.
Old 12-09-2007, 08:23 PM
I wouldn't be opposed to rolling the fenders, I don't see that being a problem. And I read a thread on here already about someone successfully running 9" wide tires on the rear, but it was an 18" wheel. Either way, I think I could massage the rear tires in one way or another, it's the fronts I'm worried about. I understand no one is going to theoretically be able to say yep that'll work, go for it. I'm just hoping maybe someone has actually done this before.
'95 SVX
'87 Dakota
'84 CJ-7
'06 CBR 600 F4i
'95 Katana 600
Old 12-09-2007, 08:28 PM
I know 19's have been done, even 20's, but not the width.
Old 12-09-2007, 08:37 PM
Just went and looked at my car (up on jack stands) and would give you a 'won't fit' answer. you will have suspension flex and sub frame movement due to all the rubber involved that you can't ever really measure. I had a similar deal with one of my former cars. I was running a 2455/60/15 on a 7.5" rim and had tire rub a few times, but met a guy w/ the exact same car (86 Monte Carlo SS) running 295/50/15's and he had no rub issues.????
I say you should try it if you can afford it.
Old 12-10-2007, 08:09 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
im imtrested
is any one running 19" wheels onthe board with a 9" or 9.5" width rims?
i been thinking abought upgrading to some 19" vlks and selling my axis to some one on the board maybe
i would really like to get a 19"+8" fo rthe front and 19"9 or 9.5" for the rear!
im current runing 18"+8" with a 40mm offset all the way round the fronts i had to roll the fender the rear fit nicely with room to spare
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 12-10-2007, 08:21 AM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
Originally Posted by solarsvx View Post
im imtrested
I hope you have an FWD version, or staggering these might not do your drivetrain any favors.
'92 SVX LS-L
Project Car for Open Road Racing
Old 12-10-2007, 01:28 PM
nope AWD the wheels will be the same diamter just the widths, skylines and a few other AWD cars have diffrent widths on there AWD long as therolling diamter is the same
i could be wrong,
Old 12-10-2007, 07:42 PM
porschekiller porschekiller is offline
Banned
Ideally, Use 245/40yr19 On The Smallest Rim Width (19x8)
Old 12-10-2007, 07:47 PM
i could be wrong,
You're correct, it's fine to run different widths. For example, the Jeep Cherokee SRT8 has a 9" wide rim in front, and 10" in the back. You just have to match your tires very carefully to get as close as you possible can to the same rolling diameter.
Old 12-10-2007, 11:05 PM
Question's Avatar
Question Question is offline
I was under the impression that lowering the offset on Subaru wheels can lead to premature wheel bearing failure, and that staying within 10mm of stock is best.
Old 12-10-2007, 11:12 PM
sicksubie's Avatar
And wave to your front quarter panels as they rip off and go flying into the cars behind you.
We won't even talk about the rears. Ideally.... If you run any size wheel on a svx with a 30mm offset you are in trouble. 30mm offset WILL NOT FIT PERIOD. The 19x9's with the 40mm offset will be tough. Crazy pilot's recommended tire size is very good, but my gut feeling is that they will not fit. Hate to break it to you. There are so many wheels/ wheel companies out there you will probably be able to find a VERY comparable wheel in an 18x7.5 or 18x8 with a better offset.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-11-2007, 12:15 AM
What is wrong with the 18's man? why you wanna put 19's? and the width... 9?
Just go by 18x8, I think this is enough in looks, fitment and weight.
Old 12-11-2007, 06:50 AM
Like I said, I'd love to find an 18X8, but the wheel is discontinued and I can't find them except in the 19X9. I might just keep watching ebay in hopes that a used set of 18s will show up.
'95 SVX
'87 Dakota
'84 CJ-7
'06 CBR 600 F4i
'95 Katana 600
