Old 06-27-2011, 04:04 PM
The Molinator
EXTRA nipple ... for Vacuum Tubing.. ?
When working on my car, I noticed an EXTRA vacuum nipple just below, to the center, and back from the Throttle Position Sensor. In other words, I saw a ~6 mm nipple protruding from the throttle "body" on the driver side .. without any tubing connected to it.. .
WELL .. What is it? AND, do I need to have tubing there? Sorry I'm so uninformed.. Hmmm?
Thanks..
Jim
Old 06-27-2011, 04:06 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: EXTRA nipple ... for Vacuum Tubing.. ?
Former coolant line for heating the throttle body? There should be one on the other side, as well. Zap us a pic, and we can tell you for sure.
Old 07-01-2011, 06:38 PM
The Molinator
Sounds reasonable! Cuz it's not attached.. and doesn't seem to have vacuum! So.. . I can just leave it open.. Huh?!
Thanks..
Jim
Old 07-01-2011, 07:05 PM
LetItSnow's Avatar
If it's not connected on the other end, either (that one is in a similar location, but points toward the firewall, angled down) then you should be fine - my Silver's just like that!
Old 07-05-2011, 01:57 PM
The Molinator
Thanks..
Jim
