CHECK ENGINE light on
morning all, just got my car back from service CHECK ENGINE light was and still is flashing.. but they have not been able to find problem . it has been suggested it could be a need for 'Knock sensor or Oxy sensor . has anyone had similar problems ?
Re: CHECK ENGINE light on
where did you get it back from? and did you get charged ? if theyre a dealer you need to give them a rev about it, they have the equipment to check the codes, if the light is on there will be a code stored in the ecu
regards cam |
yes monitor code check done . found 2 faults that was the 2 . other than that nothing
but it only came on for a few seconds . has done for a week |
As they have checked the codes, they should be able to say what is producing that code. Maybe Knock sensor or O2 sensor is a bit vague.
It is probably a O2 sensor. What model is it obd1 or obd2? Harvey.
Harvey, how you doing ?
you were my saviour a few years back when I was in Qld. with the aircon problem. these are the parts they suggested it may be . knock sensor 22060aa031 or oxy sensor 22690aa180 buy they are not sure. there are less svx's in Melbourne so harder to find someone who knows them . Joann |
There are two of each O2 sensors and Knock sensors, one for each bank. I think you should pull the codes yourself to see which sensor is the problem. You can find how to do it here,http://www.subaru-svx.net/photos/files/How-To/14337.doc and here http://www.subaru-svx.net/photos/files/How-To/14374.doc It's not hard to do, just look behind the right hand side kick panel, it will just pull off. Harvey.
Joann...I think I gave you some bits didn't I? Matt...who was from Brisbane, but is now back in Canberra!!
Matt |
Thanks Harvey, will get my other half to check it out.
Joann |
Hi Matt,
yes I did get some parts from you . Both are working fine. seems we both moved out of Qld ... |
