Tick Tick Tick
A quiet ticking sound has developed in my '95
It is not related to revs. It seems to be coming from the area behind the gearstick/radio. I first noticed it via radio interference. It ticks about 4 times a second, and continues with the motor off but ignition on. It is no more obvious from the engine bay side than inside the car. My mechanic could offer no suggestions. Anyone got any ideas? regards DonMac |
Re: Tick Tick Tick
Also could indicate a bad coil, though when engine is off you would think it would not be making any more noise. |
Re: Tick Tick Tick
When you say gear shift/radio I presume you mean it's not coming over the speakers.
Re: Tick Tick Tick
Not a mechanic, but to me it sounds like a failing relay of some sort. I have no idea what would be in that area, but presumably it would affect some electrical system. Any other weird effects noted, perhaps sunroof operation or interior lighting?
Truly a shot in the dark. If you find a cause and a fix, please post your story. Owen
-Owen '92 SVX LS-L Liquid Silver 123,600 km (~ 76,800 mi) -completely stock |
Re: Tick Tick Tick
Something stuck in the a/c heater fan? maple seed, pine needle etc.
Re: Tick Tick Tick
The a/c heater fan is located on the far right side of the vehicle, above the passenger feet.
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
