What is that noise???
I listen to talk radio and all of a sudden constant static started happening. Constant, meaning any time the radio is on in my car. I didn't think much about it at first, just thought it was probably something the liberals had cooked up so we will stop listening to the station Rush is on.
When I got where I was going to pick up my wife, My Magellan said "you have arrived", (I love that). I stopped the car and turned the ignition switch to accessory, Radio was clear as a bell. Started the engine back up and static was there again. Only when the motor is running. Just started that a couple of days ago. What is broken now?? Any body know?? Thanks, Keith |
Re: What is that noise???
either a ground wire came loose or your radio went kaput ( but since it works we know that this is not the case )if a ground came loose or a wire rubbed through then it could cause this static. it is probably feedback from the motor. it sounds like a ground came loose and it is grounding thru the antenna it can cause this unhealthy problem and does it cause static with radio off?
William |
Is your rear defroster on? Part of the rear defroster grid is a radio antenna.
Is it a white noise/static type noise, or is it more of a whine that changes with the engine speed? Your radio filter capacitor could have gone kaput as well, or perhaps a ground for the antenna? That would cause electrical interference to work it's way into the radio, and AM is pretty susceptible to interference. Then again, it could be the liberals. My radio at work seems to get staticy around 3pm when Michael Savage is on... (And my town has NO shortage of whiny liberals...)
Seriously, thanks for the help. gives me a place to start! Keith |
It doesn't seem to change the change in rpm Where would I find that capacitor? That is what it sounds like to me. That would explain the absence of static when the motor isn't running on accessory.. I guess I could try it with the ignition switch turned on to run and not start the car might narrow it a bit more? Thanks all! Keith |
Yup, you and I are about the only 2 conservatives in the whole northwest!
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
I think Obama might possibly be influential in bringing a bunch of others over to our side! That would really be good news! Keith |
