Old 05-14-2023, 09:21 AM
LarryIII LarryIII is offline
Dead SVXes
I now have 2 dead SVXes (Alcyone & SVXY). Both of them have good batteries. I suspect it is the fusible link (I don't know it's official name) that sits between the battery and the fender. I will pull them tomorrow because today is Mothers Day and The Beautiful Naviguesser comes first. I'm now 79 & getting too old for this stuff. If anyone has these fusible links I will buy them from you. Please notify me by posting here. Thanks.
Old 05-14-2023, 11:51 PM
oab_au oab_au is offline
Re: Dead SVXes
Larry the fusible link is in the fuse box, the one you are talking about between the battery and the fender is the dropping resistor for the TCU
One Arm Bloke.
Tell it like it is!
Old 05-15-2023, 11:59 AM
Re: Dead SVXes
Thanks. I checked with a local dealership this morning. None are available in the worldwide s Subie network. The part number is 22654AA060. Does anyone here have any they can sell to me? I guess it's time to start searching.
Old 05-15-2023, 08:48 PM
Noriyasu Noriyasu is offline
Re: Dead SVXes
Hello,
22654AA060 is dropping register for Duty Solenoid A of automatic transmission.
Is your SVX's engine starting fine and only having problems with the  transmission when moving?
Normally, if there is a problem with solenoid A, the POWER light will flash to warn you. The error code is 11.
I've heard that non-JDM SVX transmissions don't have power modes. Maybe it's not POWER that's on your meter cluster, but ECO or some other lamp.
Mori.
Old 05-18-2023, 12:39 AM
svxnavyvet svxnavyvet is offline
Re: Dead SVXes
Anyone know the resistance value and wattage? this is just a sand cast resister used in many electronics. it's 25W 15Ohm replacement.
eBay
https://www.ebay.com/itm/27536067453...Bk9SR_qOkdGFYg
http://www.subaru-svx.net/forum/show...egister&page=3
Old 05-18-2023, 12:51 AM
Re: Dead SVXes
same https://www.ebay.com/itm/25585322922...Bk9SR_qOkdGFYg
Old 05-18-2023, 03:15 AM
Re: Dead SVXes
Hi
I confirmed Wiring diagram and parts list again. sorry I made a misunderstanding.
22654AA060 drives fuel pump. not AT related.
Is your SVX has problem in fuel pressure? If register is no problem, it might reason of problem is fuel pump.
Is pump works ? Is there any sound from pump in the fuel tank when you turn on the ignition key (not start) ?
As far as I know, the fuel pump is often the problem, not the resistance.
It sits between my SVX's battery and the fender. The resistance value was 30 ohms in my SVX.
Last edited by Noriyasu; 05-18-2023 at 04:14 AM. Reason: correct misunderstanding.
Old 05-18-2023, 04:40 AM
Re: Dead SVXes
Hi,
I'm a little confused.
The resistor between the battery and the fender is 22655AA020. it connect via glay connector F22,
This has to do with solenoid A in the AT. The resistance value was 30 ohms.
22654AA060 is located next to the fuel control box. it connect via glay connector R44 which placed close to fuel pump controller (close to fuel pump). This resistor is in series with the fuel pump to limit the current.
Which resistance are you talking about?
