Old 11-22-2007, 11:07 AM
Manarius's Avatar
Manarius Manarius is offline
Adjusting the TPS
Could someone explain kind of the...method of adjusting the TPS? I read the how-to many times and I don't understand what exactly you move. Do you move the entire sensor? Is it the swinging of the sensor itself that does the adjustment? I'm confused on this matter.
Thanks in advance.
-Jason
-Obi Wan Kenobi
Old 11-22-2007, 11:32 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Unplug it, stick a sewing needle or something into where the white wire goes into the plug, plug it back it. Turn the ignition to "on," take a multimeter and touch the + lead to that needle and the - lead to the chassis. Swivel the tps around until it reads 5.1 - 5.2 volts. (should read 5.0 but with the slight increase your idle won't be so low)
Brian
Old 11-23-2007, 02:58 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Originally Posted by Ricochet View Post
Unplug it, stick a sewing needle or something into where the white wire goes into the plug, plug it back it. Turn the ignition to "on," take a multimeter and touch the + lead to that needle and the - lead to the chassis. Swivel the tps around until it reads .51 - .52 volts. (should read 5.0 but with the slight increase your idle won't be so low)
fixed the decimal placement...
Old 11-22-2007, 05:11 PM
Trevor's Avatar
Trevor Trevor is offline
Thanks in advance.
The how too instruction is of my making and the paragraph involved was taken exactly from the Subaru manual. If and when I can access the text I will add the words ---- (by rotating the complete assembly).
Meantime the existing data would appear OK, as instructions regarding loosening and tightening the fixing screws, should provide an adequate clue.
Trevor, New Zealand.
Old 11-22-2007, 05:43 PM
Manarius's Avatar
I guess. I think a picture would help too. I'll take a picture or two tomorrow while I'm adjusting my sensor so maybe that can be added in.
-Jason
-Obi Wan Kenobi
Old 11-22-2007, 07:10 PM
jeffast jeffast is offline
I kill more trannies then god
you are rotating the whole sensor, just loosen the two screws holding it to the throttle body and it will rotate somewhat smoothley by hand. you want to stick a pin or needle through the middle wire of the tps then hook your meter up to it and a ground source. for connecting the meter I reccomend the wire with alligator clips on both ends as they leave your hands free to hold the meter while rotating the tps.
hope this helps let me know if i need to clarify parts of it
1991 xt6 eg33?
1993 gc track car
Old 11-22-2007, 08:32 PM
Trevor's Avatar
My instructions, as is included in the how too:-
"ADJUSTING AND CLEANING THE THROTTLE POSITION SENSOR.
In order to adjust the TPS, the manual says to measure voltage at the TPS by inserting meter probes into the plug at the ECU. Nice and easy that is! In order to accomplish the feat without tying yourself in a knot you will require, best of all, one of those dress making pins with a nice thin shank and a knob on the end, or a thin needle. Also a meter to measure 0.5 volts D.C..
The TPS comprises a potentiometer, presumably used in a voltage divider configuration, as three wires come from it. There is a plug and socket close to the unit so that it can be easily removed for servicing. At this plug, the wires are --- black ground and one end of the resistance element, red the other end and white the wiping contact.
Stick your pin right through the white insulated wire so that you can clip your meter lead onto it to make measurements. A fine pin will not damage the conductors as they will spread and there will be no significant damage to the insulation. Measure between the wiper, i.e. white wire and ground, by connecting to engine, chassis, battery negative, or whatever.
Now from the book: (i.e. Taken exactly ftom the Subaru Manjuals.)
1. Connect all connectors.
2. Loosen TPS fixing screws.
3. Turn ignition on.
4. Adjust TPS position while throttle valve is FULLY closed, using a volt meter, to the specified voltage.
5. Tighten fixing screws.
The voltage is specified within a tolerance from 0.45 to 0.55 volts. You should have no trouble in setting things at exactly half a volt. (0.50)
Before removing the TPS or altering the original setting, it is a good idea to mark the mating castings with a scratch so that one can check on the adjustment, before and after, as a matter of interest. It is always nice to know if the effort expended has in fact improved things."
Surely when read completely through, the procedure is easily fully understood.
However text as per the manuals (4), could be altered as follows, if someone able to do so has the inclination.
4. With throttle valve is FULLY closed, using a volt meter, adjust the position of the TPS by rotating the complete assembly in relation to the mounting, until the specified voltage is registered. Note that slotted holes are provided in the assembly to allow for this adjustment.
Old 11-23-2007, 04:42 AM
I had a quick look at it Trevor. The document that is on there is a pdf, and like 99.99% of the b'stards, they don't allow editing.
I'm sure we can get it altered though, or replace it with a new version.
