Trying to find fuel filter
Hi, I was wondering if someone could point me in the direction of the fuel filter? Is it in the gas tank or somewhere stupid like that, or is it fairly easy to get to?
thanks for the help -=SM |
Easy one. Under the hood by the fuse box & radiator overflow tank.
The fuel filter is the bright aluminum canister located at the rear of the engine compartment on the
driver's side, with the rubber houses going to the engine. Right behind the coolant reservoir .
You just LOVE to show off your engine bay
Hah, that's exactly where it is on my car as well.
Damn hoses
hey everyone, are there any tricks for getting the hoses off?? I was not able to get them to seperate. Is there vacume pressure or anything that could be released? Thanks a lot.
-=SM |
engine compartment you look, its just perfect. Even a remote controlled Dremel couldn't get to some of the nooks and crannies that are just naturally pristine as in Harry's. ;
Thanks
Thanks a lot guys.. I may replace it tomorrow.. and suggestions on what tolls I might not think of and will need?
Thx -=SM |
You should be able to do it with just a phillips screwdriver. Those hoses get stubborn at times though so be careful not to tear them. FI hose is expensive compared to regular fuel line.
You can relieve the fuel pressure somewhere behind the passenger seat (check your manual) but it's not necessary. Just try to pry the hose open enough to spray liquid wrench or similar into it. Then pull and rotate slowly by hand. If you use a pliers, place a cloth between the pliers teeth and hose, this will prevent damage to the hose.
