wide band afr data coming soon...
I finally got my wide band O2 sensor and meter installed last night. The system is made by Innovate Motorsports. I've got bungs welded into both primary pipes, so I can log either bank of cylinders. The meter can log up to 45 minutes of data which I can download to a computer and plot. I also bought the optional analog input cable, so in addition to logging afr, I'll be logging engine rpm, TPS voltage, MAF voltage, knock sensor #1, and knock sensor #2. I haven't got the analog input cable installed yet though. Need to get some mil spec wire taps. I was hoping to get some afr data this morning, but I had to head into work. I'll have data this evening.
Sensor location: LM-1 meter and data logger:
That's awesome Mychailo. Glad you have it up and running. I look forward to seeing your results this evening!
-Chike
So why not just replace you stock o2 sensors with the wideband’s? I have been looking in to buying 2 of the Lc-1 form innovative but I have run in to information that says not to mount WB o2 so close the port. I like your setup. I very well may be running something like that soon my WB readings form my PLX M-300 are very helpful for tuning my turbo setup.
www.svxtasy.com |
A WB O2 sensor produces a different voltage response than a narrowband O2 sensor. The LM-1 meter can take the WB O2 signal and output an NB O2 signal, but then I'd have to snip my SVX wiring harness and send the signal from the LM-1 into the ECU. So, I guess it just seems easier to keep the NB and WB duties separated.
Where do you have your OEM O2 sensors located?
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 05-08-2005 at 04:47 PM. |
Right after the turbo
www.svxtasy.com |
Less than 12" from the turbo?
