Driver's side window failure
After 23 years, the driver's side window crapped out. The cable which exits the lower side of the motor had jumped off the nylon reel and gotten bound up after 2 loops. Dismantling it left a cable with severe kinks. Tried to reinstall but kinks and perhaps my misunderstanding of how the top exiting and lower exiting cable should be reinstalled resulted in a "no go" Thought I might get some new cable and repair...anyone with a working idea of how the cables should be rewound on the reel..lower exiting cable clockwise and upper CCW (viewed with motor assembly installed in door) ?? Cables wound on respective halves of the reel..?..
Doesn't look like the plastic clips that insert near the pulleys can be removed, right? (at least without removing the plug slugs that finish the cable in the reel). Anyone with a reel/cable assembly ready to be attached to the window motor? Those with knowledge of the mysteries of the window system please assist ! Thanks Last edited by fasteract7; 04-09-2016 at 03:23 PM. |
Re: Driver's side window failure
Where can I get this part...? Unfortunately the kinks in my cable make trying to reload it successfully not a possibility. A crease right near the end slug makes it pop out of the insert in the plastic reel.
http://i1235.photobucket.com/albums/...ures/41946.jpg Last edited by fasteract7; 04-09-2016 at 06:26 PM. |
Forgot to thank you for the reply. Your experience with the "windings" technique may prove helpful. Wish I could confirm the regulators for sell are the complete unit I pictured...
I fought with mine for several hours last fall until I was at the point of dousing the car in gasoline and burning it. Once the cable is kinked it's game over.
I finally removed the entire driver's side regulator from my parts car and swapped it out. I was done in about 45 minutes and it has never worked better since I bought the car 8 years ago. You should be able to find a used regulator for a very reasonable price. There are a lot of SVXs in junk yards with blown transmissions. |
Does the part listed on Subaruparts.com and other sites under the heading "window regulator" for $99-$110( only as opposed to the $349 Dealers want) contain the cable/reel to motor setup with the clips on the wire?
I ended up purchasing mine from quirkparts.com (whole assembly). Hardest part is getting the glass in alignment again.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#8 62101PA100 / REGULATOR, RIGHT (drivers) Does this look like what you ordered for about $99.71 ? Comes all set to attach to motor with plastic clips on cable...
THX Last edited by fasteract7; 04-10-2016 at 02:16 PM. |
This is a junk yard network so all the parts are used of course. |
Purchaes a new regulator, yet to arrive, and read the phantomomaku writeup for installation...anybody whose has done this installation want to chime in about the procedure..short cuts, problematic areas, other specific DIY links?
THX] |
That looks like it. Came wrapped in plastic and was not all that hard to install. Biggest problem for me was that I had lost some screws holding the regulator motor assembly to the door. After that I used the factory service manual to find the window alignment procedures. That part was the biggest pain since there are many ways to move the window inside the door. After I put it together, minus the door-card, I went through a car-wash to see how much water leaked in. You could just use a hose but I went big lol.
C : ADJUSTMENT
"Using regulator mounting nut, adjust the installation position of regulator, and adjust the door window glass protrusion by turning adjusting screw" Can you clarify this a bit for me..picture seems to show one of the lower 2 bolts that holds the rack in place. Window glass protrusion ??? Also, do I need to follow all the steps..remove outside trim, remove glass, etc. ? |
Regulator DIY...Window regulator installation.
Job done...got part from Premier Subaru, Branford CT (Ron/Sean in parts) for about $100.00 shipped. Not necessary to remove outer trim strip..removing the 2 window glass stabilizers gives enough room to remove glass and than regulator assembly. The lower regulator studs screw in/out to adjust window "protrusion" per Service Manual. I measured with a Harbor freight slide caliper the protrusion of the 2 adjustable studs ( 7mm for ft one, 5.3mm for rear, in my instance) and swapped studs to new regulator using same numbers. Thanks to all who responded to my plea for info..... |
