Sunroof seal
My seal is coming loose. How does it attach to the moving part? Does it press fit into it or is it put on using an adhesive?
Re: Sunroof seal
Just a press fit.
Re: Sunroof seal
So, if mine is coming off, does that mean it is broken in some way. Is there some rubber stuck in a groove or something like that which I will have to remove before replacing the seal?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 03-06-2018 at 09:01 AM. |
Re: Sunroof seal
I could really use an answer on this question if anyone knows. If there are pieces stuck in a groove somewhere, I will probably use a rubber adhesive to stick it back on versus pulling the whole damn sunroof off the car.
Re: Sunroof seal
The sunroof just unbolts from the mechanism.
The seal isn't much diff. from the main doors seals. Just pressure fit. Been too long for me to remember if there is a tongue & groove. I can tell you that the seam between the two ends should be at the rear. When I had my car painted the shop put it on backwards and it only took a few minutes to remove & reinstall.
Re: Sunroof seal
65441PA002 (65441PA000; 65441PA001) $175.00 The seal is one continuous strip. Start at the center of the rear of the sunroof and press it into the groove slightly all the way around. But the time you get around the whole way you want slightly more rubber left over than the space you have to cover (maybe an inch). Then butt the two edges together tightly and push the excess into the groove (in effect compressing it) If you stretch it to fit, it will soon return to its unstretched state and leave a gap between the ends. It may take a couple of tries to get it right .
Re: Sunroof seal
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 03-09-2018 at 07:54 PM. |
Re: Sunroof seal
Just doing a quick search found it for much cheaper somewhere else. Hopefully you didn't purchase yet.
https://www.subaruautomotiveparts.co...xoCAN0QAvD_BwE
Re: Sunroof seal
Re: Sunroof seal
If the front of the seal is detached, does that mean it left some of itself behind where it pressed into the panel? If so, I am assuming I need to remove the panel to pick out the broken bits.
Re: Sunroof seal
Possibly, but if you slide the sunroof back, you should be able to see the front area to see if any "Bit" left in the rain gutter
Re: Sunroof seal
Thanks all. I had success putting the new seal on. Much drier now and much less wind noise.
