Old 01-16-2019, 06:43 PM
jes's Avatar
jes jes is offline
Question PCV valve location?
I haven’t found any decent pictures of the PCV valve. Only hints, like it’s under the throttle body. I see nothing that resembles a PCV valve in that area... is it hidden under this F connector? (not swearing, it looks like an F)
File Type: jpeg 316744D7-05F2-45AE-91BC-30384542DAA2.jpeg (690.3 KB, 586 views)
File Type: jpeg 720A69F6-2A9E-4067-AFF7-1D38FE1D0222.jpeg (461.1 KB, 197 views)
Old 01-16-2019, 09:08 PM
oab_au oab_au is offline
Re: PCV valve location?
Have a look here.
One Arm Bloke.
Tell it like it is!
Old 01-17-2019, 01:17 AM
jes's Avatar
jes jes is offline
that's the underside of the intake manifold?? I'll have to see of I can feel it. Is it even serviceable w/o removing the manifold?
Thanks
Old 01-17-2019, 02:05 AM
Thanks
Yes it is, fortunately, if you pull the black cover plate off the center of the manifold, you can see it, but read this thread before you try.
http://www.subaru-svx.net/forum/showthread.php?t=57076&highlight=PCV+VALVE+removin g
One Arm Bloke.
Tell it like it is!
Old 01-17-2019, 06:06 AM
Here is the pdf document with photos of the PCV replacement process.
Found in the Engine section of the How-to documents.
http://www.subaru-svx.net/forum/atta...5&d=1271113497
NOTE: The PVC is mounted from the bottom of the manifold and so everything is reversed when removing it from the top; the wrench is turned in the opposite direction of what you would think. This is also noted in the instructions.
When removing the valve from the top, turning the wrench CLOCKWISE actually loosens the valve. Turning it COUNTER-CLOCKWISE actually tightens it.
