Old 02-01-2010, 03:59 PM
aust92pearl aust92pearl is offline
rotors and pads ?
fairly cheap
reckon they would be any good ?
http://cgi.ebay.com/ebaymotors/92-93...Q5fAccessories
Old 02-01-2010, 04:07 PM
Re: rotors and pads ?
Joel, if you're looking for replacements, you will want to check out options of cross drilled and/or slotted rotors and ceramic pads. Will get better life out of those pads, and they will generate less heat meaning lowered chances of the rotors warping.
Old 02-01-2010, 05:24 PM
oab_au oab_au is offline
Originally Posted by aust92pearl View Post
fairly cheap
They are pretty heavy to send out from the states, have you tried DBA?
One Arm Bloke.
Tell it like it is!
Old 02-01-2010, 06:24 PM
no i havent tried dba lookin at it now
dba's are expensive lol $186.25 each for normal ones
$326.00 each for slotted
just saw them on ebay n though id post
Old 02-01-2010, 08:49 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
The deal sounds ok, but as far as brake rotors go, I would never buy a set that I couldn't hold in my hand first, just to inspect thickness and weight.
Old 02-02-2010, 01:32 PM
SVX_MY_BABY's Avatar
My setup is getting close to replacement so I got current prices from Applied Rotor Technologies. Pretty fair price I thought.
Hello Peter,
Thank you for your patronage, it seems the ART Product has served you well for many years.
The cost of the ART Front & Rear Brake Kit on your 1992 Subaru SVX 4WD would run you $514.00 plus shipping & handling to your zip code.
The ART Brake Kit consists of gas-port slotted, cryogenically treated brake rotors along with a set of Posi-Quiet Extended Wear Semi-Metallic Brake Pads.
We can provide you with the O.E.M. Posi-Quiet Unloaded Front Calipers (rebate available upon return of original caliper cores) for $100.00
If you decide to order the entire Front & Rear ART brake Kits with Front Calipers, you would receive a 10 % discount.
Please keep in mind that each ART Brake Kit is custom engineered, manufactured, & cryotreated in-house and your order may involve a lead time.
ART Brake & Suspension Systems may be purchased by order over the phone at (714) 527-9400.
Thanks for your inquiry.
Padmanabhan (Pad) Nilakantan
Applied Rotor Technology
www.appliedrotortechnology.com
Office / Fax: (714) 527-9400
If you call them make sure you tell them you're a member here.
Peter
