Electrical Issue
Alright, to start off, about a week ago someone broke into my car and stole the battery and messed up the main power and ground wires. I just got around to fixing the wires and now have a problem.
Basically, everything that should work without the key on works just fine-interior lights, hazards, power locks etc. Also, when the key is put in the ignition, it makes the normal annoying beeping. But, when I turn the key forward, there is nothing, no clock, no radio, no pwr windows, no headlights, turn signals, etc. I have double and triple visually checked the wiring and it all appears in tact. The fusible link and all fuses appear to be good. Basically, I'm not the greatest when it comes to wiring. If someone can point me in the right direction of whatever could cause this to happen. I would imagine it would be a rather short list since everything that works with the key off does, and everything that should work with the key turned forward, doesn't. Thanks in advance. Also, I do have the battery on a charger because I'm not 100% sure on how much charge it has, but it was just used a few weeks ago to start and move around a car. Also, even with a low battery, the clock should at least come on if the interior lights work. Also, turning it forward, the interior lights don't shut off. Edit: helps to add that this is my 94 laguna L model that i'm dealing with so no security involvement either, even though that wouldn't do what this is doing. And I'm trying to look through the wiring diagrams but i'm not the type of person who is able to translate something on paper to what's actually under the hood. Last edited by 1986nate; 08-24-2010 at 10:10 AM. |
Re: Electrical Issue
nvm, Thank you Tom (SVXfiles). Turned out the blade for the fusible link was "pushed down" from the fuse box due to the careless "removal" of the battery. Tom guessed it right away.
Now to figure out what else got messed up that it's got a miss |
yeah for tom!
"it makes me want to punch a baby...."
I only just now learned about this issue from your facebook ranting, glad you got it resolved without clobbering the nearest infant |
This week is going much better (for a few reasons) after last week just felt like a kick in the nuts. |
Now I just keep everything out of sight, I dont want the screw-drive crew doing any of that to my SVX, or im going Predator on any poor soul casing cars here at night. |
Nate, you said you where sending me the 2 interior pieces that I asked you for when I bought that POS from you. I still haven't got them. So, were you just lying to me when you said you could send them to me? I got the tires you sent, but they are almost as bald as the ones on it, and you said they still had lots of life left.
1992 SVX LS-L: For sale 1995 Lexus SC400- Lexta Z Last edited by SpadedOne; 08-27-2010 at 12:01 PM. |
