Gasket Problem?
When changing the oil in my 96 SVX, I noticed something leaking at the bottom of the ....thats my question, I don't know what part this is. As you face the front of the engine, its that black plastic cover thats on the left, immediately in back (towards the firewall, about 2 inches behind the radiator) of the radiator. It extends from the top of the engine, to the bottom. A similar type of cover is on the right hand side which i think is the cover for the timing belt.
Anyway, at the bottom of this plastic thing (you only see the bottom of it with the plastic shroud removed from under the car to get to the oil filter) part of a rubber gasket is visible, and its leaking something. Sorry for the very unclear description. Hopefully someone will read this and think "hey, I had that exact same problem and its the ________ (fill in part here)". Thanks. Larry |
Re: Gasket Problem?
Sounds like either your cam seal or cam plug is leaking.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Re: Gasket Problem?
Agreed....
You should re-place both cam seals and the front crank seal...theey are only about $7 each...but you have to pull the timing belt to do them, so it'd be a good time to replace it too.
Re: Gasket Problem?
I think what youre seeing is the timing cover seal, when oil seeps from your cam seals it pools at the bottom of your timing cover and leaks out from there. Timing belt replacement is a cakewalk.... but to remove your camshaft pulleys you have to use a special tool, or your old timing belt wrapped around them and secured on part of the engine, to keep them from turning when you remove the bolt. You can do the whole job with a basic socket set pretty much.
Re: Gasket Problem?
A chain wrench works well for that - I picked up a beefy one from Harbor Freight for around $15.
'93 Legacy LS (will last longer than the cockroaches) '94 SVX LSi |
Re: Gasket Problem?
OK, so the suggestion is that I replace the timing belt at the same time I replace these seals. How hard is to replace the timing belt? I had the dealer do it at 60K miles, and always thought that it was fairly difficult. Are there any clear instructions anywhere? Thanks.
Hey, RedLighteningSVX, mine looks just like yours. Larry |
