Old 04-26-2003, 08:54 AM
gcookaustin
What brands of CD-Rs will work in the SVX player?
What brands of CD-Rs will work in the SVX player? Has anyone gotten a particular one to work properly? I've tried a few, and they are either not recognized in the CD player, or the player seems to search around a lot and get messed up. I've used a lens cleaner before but to no avail.
Old 04-26-2003, 09:15 AM
tong
Almost all i used work great. Mainly the memorex ones. I even used the mini cd-r's and it played them no prob. Haven't found one that didn't play. Try a lens cleaner see if that allows you to play the ones that didn't before.
Old 04-26-2003, 09:16 AM
vzSvx's Avatar
vzSvx vzSvx is offline
Send a message via Yahoo to vzSvx
I have used different brands of CDRs and they all worked on mine except the CDRWs...they skip a little. I have an Aiwa MP3 player though, not the stock SVX CD player.
- Viv
1992 SVX LS, Claret "Caressa"
"Striving for excellence motivates you. Striving for perfection is demoralizing.".
Old 04-26-2003, 09:37 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
If you have a really fast burner like a 24x, 32x, 48x, or 52x, slow the recording process down to 12-16x. Sometimes the cheaper brand burners dont do a very good job as the speed increases. I've seen that problem a lot, and also make sure you close your cd after the recording process is done.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-26-2003, 03:29 PM
DavieGravy DavieGravy is offline
Either CDRs will paly or they won't. The only difference between brands is that some scratch easier and are more prone to errors from scratching and fingerprints than others.
Out for good.
Old 04-27-2003, 11:40 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
Do your burnt CDs play anywhere else? i.e. someone elses car deck?
Lets just hope its your Software???
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 04-28-2003, 01:11 AM
Personally, I was never able to get CDRs to play in the stock SVX player. I've heard of other members having sucess. Me, I decided to say the hec with it and switch out the deck. If cleaning doesn't work, I'd suggest you do the same if it's really that important to you.
Out for good.
Old 04-28-2003, 05:56 AM
I have some that will play and some that won't, the ones that won't are black instead of silver...don't know if that's the reason, but they won't play.
Old 04-28-2003, 07:58 AM
Paxton71
green CD's won't play
Mine won't play green back CD-R's. That is all I have tried. Skip-0-matic.
Old 04-28-2003, 08:04 AM
Green1995SVX
I've had no trouble with any CD-R's. My cd player spits out cd's on really cold days (sub-zero) until the interior has warmed up. That's my only problem.
Mike
Old 04-28-2003, 08:51 AM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
I use Memorex or TDK and burn them at 48x using a Kanguru burner that was pretty cheap. Both brands work fine in my stock player.
Different players (even of the same brand) seem to like or dislike different brands of CD-Rs and even different brands of burners. A Memorex CD burned in my Kanguru may play fine on my Sony home player but not on your Sony home player. For lots of information on this, check out
www.cdrfaq.org
More info than you'll ever need.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 04-28-2003, 09:01 AM
StaceyVX
Yep, I experienced this too. Actually the first time I tried a burned cd ( I forget if it was a CDR or CDRW), it didn't read it at all. I was really bummed because I thought that meant I couldn't play any burned cds. I tried the next day for the hell of it and it worked.
Old 04-28-2003, 11:46 AM
SvXit's Avatar
SvXit SvXit is offline
Member Incognito
Re: What brands of CD-Rs will work in the SVX player?
Have a go at the Memorex Black CD-R's. I use them to make compilation cd's all the time and have heard from more than a few folks that the sound quality is a little better and they work well in systems that don't normally accept CD-R's.
SvXit
"Flossie" - 92 black over pearl LS-L (sold)
"Gorgeous George" - 98 Audi A8 (traded)
"Gorgeous Genny" - 02 Audi S8 (sold)
"Green Giant" - 00 Land Rover Disco II
"Grey Wülf" - 05 Volvo S60 R
"Silver Surfer" - 92 black over liquid silver LS-L
"9 of 7" - 97 bordeaux pearl, formerly with Earl Steele
Old 04-28-2003, 11:27 PM
Re: Re: What brands of CD-Rs will work in the SVX player?
That's a myth by the way.
No matter what brand, the same, actually, very similar digital information (0s and 1s) is printed on the CD. So there's no way a noticable variation in sound quality can exist between brands of CDRs.
Looks like people still need to get out of their cassete tape/analog recording mentality.
Out for good.
Old 05-01-2003, 05:26 PM
Mine played CD-R's until the player became too hot then it started to skip/jump around very bad. The area under the unit gets very warm. I found that if I removed the ashtray it lasted a little longer.
