weird wire
Just ran across a red wire behind the diagnostic cover on the drivers side footwell.It almost appears to be round romex! Looks like it might be 16/2 or maybe 14/2. The end is clipped neatly so I 'm thinking factory and it runs under the carpet towards the back of the car. Anyone else seen this on their car? I just noticed it tonight while trying to fix the dreaded 'battery drain' syndrome As always, any help is appreciated.
dennis |
Re: weird wire
could it be a amp/subwoofer control/power wire that runs to the trunk?
Re: weird wire
possibly a power antenna wire? does ur power antenna work?
Re: weird wire
Dennis- What you are describing does not sound like a factory wire. My best guess is it may be a remnant of a car-phone which may have been installed at one time. Additionally, I would check around for any additional wires that tap into you 12v/accessory wires as an aftermarket accessory installation done improperly will lead to a battery drain issue. Hope this helps.
1991 SVX L JDM |
Re: weird wire
Thanks to all. Mike, I do have a remote alarm/start device but I disconnected it and still have a drain. Alternator seems OK. No internal ground. Time to start the process of elimination I guess. I think I'll track the red wire down just out of curiosity. It seems that it only does this during winter months. Thanks again for the help. Antenna is fine also. No amp/sub just factory. Will report back with the cause when I find it!
Re: weird wire
You can easily determine which circuit has a draw by pulling one fuse at a time and seeing if the voltage at the battery changes. If it does, then that is where I would start to look. I read here that if you have a draw, it will drop the voltage down at the battery a noticeable amount. Good luck. Electrical gremlins are the worst.
Re: weird wire
For information on how to diagnose a parasitic drain on your electrical system, check HERE and HERE .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-12-2011 at 09:12 PM. |
Re: weird wire
Thanks guys. thanks for the links. I wish it wasn't 3 below i'd be working on it right now. Suppose to warm up tomorrow to a whopping 20
dennis |
