Old 10-15-2017, 07:06 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
WTB Lock/Unlock mating harness
Hi fellow SVXers,
been wanting to add the following switch next to gear selector, but require the mating connector and short length of the OEM wiring loom (about 3-6 inches).
The connector is a 5-way (3-up / 2-down) with clip within the plastic housing.
TIA.
Let me know by PM cost, postage to me in New Zealand.
Old 10-17-2017, 07:22 AM
SURTEESS's Avatar
Re: WTB Lock/Unlock mating harness
still looking for the mating part....
Old 10-17-2017, 08:18 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
The wiring loom should be there. I see no point in them removing it for certain vehicles. Unless your car is pre-94?
I have the wiring loom, I don't really want to cut it out of my harness but if you really need it and the right amount we can work a deal.
-Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 10-17-2017, 10:17 PM
SURTEESS's Avatar
The option was not available here in New Zealand, hence I would like to make it happen. Maybe the same connector is used on other Subaru's of same period also for central locking?.
