aftermarket power antenna
http://www.pepboys.com/product/detai...rior/antennas/
Has anyone used this product? The web site says it fits an SVX. Wondering if that's correct... |
Re: aftermarket power antenna
For that price you could replace just your mast, if that is the only thing wrong.
part# 86322PA010 $55.40
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Michael, no disrespect intended, but have you personally replaced a Subaru SVX mast? Twenty year old plastic/screws/grease/gears/etc./etc. It should take at least an hour less if the product actually fits.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 01-25-2013 at 06:34 PM. |
The better question is what would give the best reception. I was surprised at how mediocre my reception is with the new Pioneer radio. It has the top of the line tuner from Pioneer which is known for its tuners.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Yes I have replaced one, and it wasn't as bad as it sounds. That was at least 6 years ago tho.
My concern would be the shape of the antenna motor assembly. The OEM one has a bend to it so that motor sits more horizontal. Would a straight one fit in the space?
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
However the one that just changed in my 253k Pearlie was a plastic breaking, rusted screw PITA.
I found a used OEM one on ebay for $30 + shipping. I'll let you know how it goes.
I've replaced a mast, including manually rewinding the nylon leader. Definitely a pain, but if I can do it, anyone with the least bit of mechanical inclination and a bit of patience should have no problem.
I've also replaced the entire assembly with a used unit purchased from a member here, and that's definitely the option I'd first explore should the need arise again. dcb |
Update...
The one I received via ebay was for a later year no doubt. The interface at the tip of the mast and the top are not quite right. My top did not fit right so its a no go. Think i will just bight the bullet and order a new one. It's only money... |
I agree, the shape is what needs to match unless you buy a stationary antenna like a rubber pig tail.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
So is this part/part number still available? Went looking at mine since it was stuck in the extended position when I bought it and looked bent. Plugged it in and it retracted half way, so the motor works. An aftermarket power ant doesn't look like it will fit due to the fender well being so close (guess that's why subaru designed the curve tube for it). Looks like the replacement mast would be the easier way to get this going again and probably the same price for a functional used one.
01- Impreza RS Original Owner 92- SVX LS-L |
So I got my OEM replacement and it works beautiful. Only thing is it has an additional grounding wire that was not on the original antenna, and there is not a handy screw to attach it to. So I left it hanging. Both AM and FM seem to be coming in fine w/o any engine noise. I could ground it with a new screw. Comments?
Thread Tools | |
Display Modes | |
