Old 12-14-2011, 02:43 PM
Jay Wrix Jay Wrix is offline
no climate control!
hey all, went out to go to work, only to discover my windows were fogging, normal for this time of year in michigan, clicked on the defrost.
NOTHING, no heat, no defrost, no fans, no clock.
I couldnt seem to find anything in the manual, or around. fuse for the clock was good
is there anything else i should look for, is it an easy fix, do these go bad?
thanks for your help and happy holidays!
Old 12-14-2011, 03:05 PM
Uncamitzi's Avatar
Member #447
Re: no climate control!
clock fuse? surely you checked the AC and Heater fuses
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 12-15-2011, 10:06 AM
yes clock fuse, clock powers gone too, and interior lights/, checked heater and ac fuses too.....
Old 12-15-2011, 10:47 AM
Uncamitzi's Avatar
Member #447
I've had that unit out a couple of times. The clock being out throws me.. you may simply have a lose connector on the Climate control unit... it snaps in pretty tight so I doubt that's the problem. but I can't think of anything else.
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 12-19-2011, 03:41 PM
thanks so far, still no heat or defrost, and its gettin frosty out here!
i checked all fuses and all are fine, i dont know how to dis assemble the
unit, how is this accomplished, are they prone to failure, please help!
Old 12-19-2011, 07:40 PM
Check fuse No.3, in the under dash panel.
Check fuse No.25, in the main box under the hood.
