Old 10-15-2010, 02:31 PM
Huskymaniac's Avatar
Uses the ignore feature
Front sway bar end links.
There are two aftermarket brands on ebay and they look very different and the cost differential is huge too:
http://cgi.ebay.com/ebaymotors/91-97...item4831afbd4d
http://cgi.ebay.com/ebaymotors/2-FRO...item4a98d564f7
Any comments on these? Not sure if I need them but, if they are the source of my less than quiet ride, I would like to get ones that last. Some may recall that I get a subtle squonky/clunky rattle over bumpy roads.
Tony
Old 10-15-2010, 03:13 PM
Re: Front sway bar end links.
The first link are adjustable, if you are very concerned with improving the hadling of your SVX. The second link is for replacement of stock.
To check your links, pull the front wheel and try to shake the joint around. You will be able to swivel it on the balls, but there should be no in/out, up/down, side/side play.
