Old 04-28-2010, 11:53 PM
Gamesy's Avatar
Gamesy Gamesy is offline
hard shifting
the transmission off an on has been hard shifting and for a moment it wouldnt go into reverse so i put a bit of gas and it jerked violently.
Will adjusting the brake band do anything or is it another issue?
Old 04-29-2010, 04:03 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: hard shifting
My tranny went bad once the reverse stoped working. Sorry.
Old 04-29-2010, 09:53 AM
Gamesy's Avatar
Re: hard shifting
reverse still works its just the one time it jerked into gear after that it was smooth again
Old 04-29-2010, 10:19 AM
Re: hard shifting
You should check the resistor and connections mounted behind the battery and run a diagnostic check on the transmission. First read up on the subject in the how too section, so that you know what you are about.
Old 04-29-2010, 08:27 PM
Gamesy's Avatar
Re: hard shifting
all i found was a picture of where it is i didnt find any how-to's to diagnose it.
do i just use a voltmeter to diagnose it?
Old 04-29-2010, 08:40 PM
Re: hard shifting
I must check the “how to” because data should be there.
You will have to test the resistor for correct resistance using an ohmmeter. (Ohms scale on a multi meter.) It should measure between 9 and 15 ohms. Make sure you check the associated wiring and connections.
