Old 03-30-2010, 12:49 PM
Naru's Avatar
Naru Naru is offline
Re: big overhaull
of for now, lets change the sparks plugs.
start by remove the air filter cap.
remove the bottom of the filter case.
and now remove the filter case bracket.
theres is space now, right?
so now, unlock all of the screws of the high voltage thing ( forgot the name soozzz )
and remove it.
now, fun part, use a mid_long key to remove the sparks.
for the front and center ones, i use this one :
and for the rear one, i use this one :
Old 03-30-2010, 12:50 PM
Naru's Avatar
Re: big overhaull
change the sparks.
and reinstall all things in the reverse order.
i have change the air filter too
i have clean the MAF too.
install the air filter case cap, reconnect all and lets do the other side .... tomorow!
see you tomorow!
Old 03-30-2010, 12:55 PM
Naru's Avatar
Re: big overhaull
Excellent thread, Naru. Very detailed and precise. Easy to understand even with the "slight" language barrier
thanks to you!
yeah i know : i'm french and my english is not really good.
but i think it's understandable.
Old 03-30-2010, 01:14 PM
Re: big overhaull
LOL, nice writeup Naru, you want to know what I saw under my manifold the last time I "visited" my SVX? --> the bones of a dead mouse!
Old 03-30-2010, 05:01 PM
Naru's Avatar
Re: big overhaull
i dont figure the SVX is a deadly car xD
Old 03-30-2010, 09:33 PM
siceclipse's Avatar
siceclipse siceclipse is offline
Re: big overhaull
why didnt you do the water pump?
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 03-31-2010, 03:34 AM
Naru's Avatar
Re: big overhaull
already changed few years ago ( the only receipe i have about this car! lol )
Old 03-31-2010, 10:02 AM
Naru's Avatar
Re: big overhaull
3st and last day
ok lets change the driver side sparks.
lift up the car and remove the wheel.
find the plastic plug in front of the rear spark.
remove the wheel well plug and the plug in the engine bay.
now you can see the spark trough it.
now, u need use an good key to remove the spark
for me i use this one :
change it as usual.
for the center and front one, no problem, do as usual.
it's very easy whitout the battery
Old 03-31-2010, 10:03 AM
Naru's Avatar
Re: big overhaull
now, lets change the oil.
first, open oil feed plug.
remove the gauge too.
now put someting bellow the engine to keep the old oil.
open the plug and wait to drain all old oil. ( it's a 17 wrench )
during the leak, clean plugs and gauge.
change the plug seal.
and reinstal it when draining is complete.
now, use a good wrench to remove the old oil filter, and replace it.
it's ok to feel whit good new oil.
check the level! ( 6.5L )
when ok, instal feel plug, gauge and all necessary things.
start up the engine and check if there is no leak.
check if all is ok, and if you dont have forgot some tool in the engine bay.
clean all a little.
Naru's Avatar
Re: big overhaull
wait until the car is hot, and check levels ( look out for cooling one! )
if all its ok, go take a test drive.
and now be happy!
my 95' svx is now like new!
hope this topic can help someone.
and thanks to coms and view for the others!
see ya later
Old 03-31-2010, 02:07 PM
kwren's Avatar
kwren kwren is offline
Re: big overhaull
Good information...
Thanks!
Keith
Old 03-31-2010, 03:16 PM
siceclipse's Avatar
Re: big overhaull
yeah, everything is layed out very well in this.
SHOULD be made into a HOW TO.
Mike
Old 03-31-2010, 04:24 PM
Re: big overhaull
Naru, give you 9.99 out of 10 for that job, well done.
95 models are the best.
Old 03-31-2010, 04:42 PM
Re: big overhaull
Kia ora Nuru,
I second the above. Congratulation, you have put a lot of effort into this. After some slight editing it should certainly be included in the "how too" section. Make sure you receive this just reward and recognition.
Old 03-31-2010, 09:46 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: big overhaull
This all is stuff I should definitely know how to do and I have watched svxfiles do it many times but it never really sank in. Now I know where to look if I ever move away from the area..
Thanks for the details and the pics.
