Old 12-20-2007, 02:15 AM
Francis Francis is offline
....fluid squirted out
i've pulled the dip stick of the transmission to check trans oil...the fluid jerked off on me, ...was it an overflow ? , the temperature of the fluid was dammmmnn hot,
Old 12-20-2007, 02:16 AM
i guess its not supposed to have pressure coming out this way....
Old 12-20-2007, 03:25 AM
That's embarrassing, all right.
Francis, if the transmission is overfilled it leads to pressure and it tends to push oil out the dipstick tube.
If yours has a very tight fit, it may have been under pressure, and spit out when you let off the pressure.
Check the fluid level from cold, but after a short warm-up spin. Then see if you need to take out some oil.
Old 12-20-2007, 07:36 AM
n00b on demand's Avatar
wtf is up with the thread title
Old 12-20-2007, 07:50 AM
I dunno Noob.
I'm kinda hoping it wasn't the way he pulled the dipstick.
Old 12-20-2007, 08:06 AM
If it was that hot, I would change the fluid. It probably got burnt and will lead to failure. I would also get an external filter and cooler installed right away. Heat will be the end of your tranny if it has not already been damaged.
Old 12-20-2007, 11:29 PM
thanks , lol somebody changed the title ...oops.. haha
