Re: front axle replacements
you could just go to autozone to get the junk one. it will look nice and good, but GUARANTEE it is junk. For whomever this place is that s going to build a superior axle, they need to use Subaru boots. Aftermarket boots are like bread wrappers, Subaru boots are thick, tough and long lasting.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
OK silly question - What the heck is a "Level 5" axle .... how does one equate L5 Vs L4 Vs L3 etc
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
The different levels refers to the horsepower that the axle can handle w/lower numbers being for less horsepower and the higher the number the stronger the axle to handle the higher horsepower.
I decided to have Thedriveshaft shop build new axles for the SVX. The axles will be overkill for the SVX at level 5 but they are the same price as OEM axles. I bought a used OEM axle to send them for correct measurements so in the future they will have a OEM prototype sample and not cheap Chinese junk.
