Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 03-04-2010, 09:45 PM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Re: Recent Exhaust upgrade Pics.
I mean from the engine and out?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 03-04-2010, 10:28 PM
92 SVX 92 SVX is offline
If I have it on a hoist, and have my camera I will. Though what your seeing is very close to the engine, less then a foot I believe.
Old 03-06-2010, 03:45 AM
Alex-svx's Avatar
Ok, I just was woundring if you just cut from the manifold and start the exhaust from there. Or how you have done it. I really want to twin exhaust on my car too.
Alexander (Norway)
My subarus:
Old 03-06-2010, 09:33 AM
ok I understand. well I had the exhaust guy cut the pipe before the connection to the single. Which means to do trans work it needs to be unbolted at the manifolds now. Without more extensive customizing this is the easiest way, otherwise you fabricate o2 bungs and such.
Old 03-07-2010, 04:28 AM
Alex-svx's Avatar
Ok thanks for the help.
I will take a look on my car when it fhinish whit the 5speed convert.
Alexander (Norway)
My subarus:
Old 10-01-2017, 07:09 PM
ok about a week later sounds different
Fixed it as per my instructions HERE
Old 10-03-2017, 11:59 AM
Wow this is an old topic, my exhaust has gone through several changes since that point. First I completely redid all the piping from the stock header all the way back is now 2.5 inch diameter, the glasspacks are pushed forward to about the stock precat locations, V-band clamps behind these with v-band clamps mounted by the rear axles as well so I can take a section of pipe out to work on things.
Here are a couple pictures right before the current setup, all 2.5 inch piping.
Old 10-03-2017, 12:07 PM
here are a couple recent sound clips
