Old 04-03-2002, 02:28 PM
double0bondo
is this bad??
i was wondering if it is bad for the car to put the FWD fuse in and run it just like that???
Old 04-03-2002, 03:26 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I've read that the flow path inside the transmission is changed when the fuse is 'in' and can result in no oil going to lube certain parts. It's only meant for short durations, such as emissions testing, etc.
Beav
Old 04-03-2002, 03:55 PM
Uncamitzi's Avatar
Member #447
Unhappy fwd Fuse
Before I knew better, I drove the car about 550 Freeway miles with the fuse in. When I learned that there was a fuse, I was worried the prev owner had put it in to mask a problem. I took it out and prayed to the SVX Gods. 5000 miles later the rear end is quiet and the tranny shifts like new. For what it is worth....
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 04-03-2002, 04:10 PM
Mr. Pockets's Avatar
Moderator
Randy drove his SVX with a Legacy tranny in for a couple thousand miles with the FWD fuse in...for what it's worth, the tranny still worked fine at the end...
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-03-2002, 05:22 PM
I_Alcyone_I
i think the previous owner put the legacy tranny into mine. What do i do? get a legacy rear diff?
Old 04-03-2002, 05:36 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Ask Randy(aredubjay) on howtos on that topic.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-03-2002, 05:42 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Actually, when all was said and done, I had driven the tans with the fuse in for just under 10K. She was still as smooth as silk when I had it replaced with a real SVX tranny.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-03-2002, 05:45 PM
Aredubjay's Avatar
That's one solution, but, I think you also have to get the axles. That might be a Huck question. I didn't go that route.
Randy Johnson
Old 04-03-2002, 11:14 PM
I_Alcyone_I
hopefully i'll be able to afford a 5 speed soon. Hopefully the drivetrain holds out that long.
