Old 12-10-2005, 06:54 PM
1320boy's Avatar
1320boy 1320boy is offline
Team ROUND 1
Send a message via Yahoo to 1320boy
Power Window Problem
Im wondering if there is a fuse or something else wrong with my passanger power window.
I dont want to have to replace the motor for it so is there something that i can do or check???
Im very And its only my passanger all the others work.
Can someone help me?
Old 12-11-2005, 06:48 AM
immortal_suby's Avatar
Thread Killah
Could be a number of things.
Do you hear a motor turning when you try to open the window or do you hear nothing?
You will have to remove the inner doorskin to get a look at it before we can help any.
Locker Link
2015 BRZ Limited 6MT
Old 12-11-2005, 11:53 PM
1320boy's Avatar
Team ROUND 1
But im wondering if there is a fuse that i can check before i start ripping things apart????
Old 12-12-2005, 12:08 PM
billb billb is offline
Does the passenger window work from the driver's switch? How about the rear windows? I thought my rear windows were working, but they were only working from the driver's switch. Do they work from the driver's switch and from their own switches? Make sure.
If your problem is that the passenger's window does not work at all from any switch, then the fuses should be OK. You'll have to start tearing into the door to find the problem.
Bill
94 SVX LE 130,000mi
Old 12-12-2005, 08:30 PM
1320boy's Avatar
Team ROUND 1
son of a *****
i was hoping that i wouldnt have to tear **** out.
but i want to make sure, where is the fuse just incase. all the other windows work just not the pass front
Old 12-12-2005, 08:32 PM
1320boy's Avatar
Team ROUND 1
son of a *****
i was hoping that i wouldnt have to tear stuff out.
Old 12-12-2005, 08:58 PM
kuoh kuoh is offline
Actually, the door panel is pretty easy to take off. Just pray you don't have to replace the rear speakers, now those are a pain to get to.
KuoH
Old 12-13-2005, 05:23 AM
I agree that the door panel is easy to get off. I was afraid of breaking a bunch of clips but there was no problem. I'll have to look up where the fuse is tonight.
Bill
94 SVX LE 130,000mi
Old 12-13-2005, 12:46 PM
1320boy's Avatar
Team ROUND 1
Thanks man i really just want to check that before i think that i have to replace a motor when i really didnt have to
Old 12-13-2005, 01:13 PM
I'll look tonight. I'd still be optimistic that it's the switch and not the motor. The switch from the driver's control gets routed through the passenger's door switch.
Bill
94 SVX LE 130,000mi
Old 01-08-2006, 05:45 PM
1320boy's Avatar
Team ROUND 1
Yeah yeah. but i hear a clicking sound
nothing "LOOKS" out of place, but then again i didnt build the car niether.
Old 01-08-2006, 06:26 PM
Thread Killah
pop the drivers door skin off and look at it vs. the passenger side - something must be different.
Locker Link
Old 01-28-2006, 06:11 PM
dromano's Avatar
dromano dromano is offline
window issues
today the driver side window stopped working, buzzing sound, no movement, the passenger window works, the driver side rear works fine, the passenger side rear is not responding. The driver side was about an inch from closed, I touched it and it zoomed into the door????????????????????????? no response to the switch???????. Where do I start????/
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 01-28-2006, 06:35 PM
Thread Killah
sounds like the sleeve lock regulator snapped. it's a pretty easy fix as long as you don't mess with the up/down switch now and the cable hasn't come off the track. pop "sleeve lock regulator" into a search - there are a ton of threads with pics on replacement of it.
Locker Link
Old 01-29-2006, 01:44 PM
dromano's Avatar
Can't find it!!!
Got inside the door, now have taped up window Looked for sleeve lock regulator, not to be found, the 'T' slot in the metal is empty. The cable works fine using the switch. Since I have 2 92's I'm ordering 8 of these puppys. I tried the right rear window switch, the one by that window, it works fine, the switch for it in the driver's door is slow and jerky???? Thanks for the help
