oil change question
Going to change my oil this weekend... I've Never done this before. I want to test out Mob1l's 15000 mile oil.
what viscosity of oil do i need to use 5w-30? also what kind of oil filter should I get? thanks sorry for being a "tard", I'm Just new to this stuff |
I allways use 10w-30.. When u goto the store, they should be able to tell you which filter you need, or there will be a book that can tell you.
-Khalil *1992 SVX Red. Now 100k and climbing Tranny rebuilt @ 84k. Repaint @ 87k. Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K. |
I guess worse case scenario I can Take it off First and take it down there and match it up....
Still If anyone knows What kind lemme know |
Oil Filter
I use Fram filter's on mine,along with Valvoline oil....10w-30.
The Fram # is 3593...go here to decide which 3593 filter you would like to use...http://www.fram.com/
Mike.... 8/96......Vin 100109 1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!! Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines. 1997 SUS Legacy,finally got the engine in after a year!! My Locker www.myspace.com/devilhornz |
Remember the SVX takes more oil than most cars so make sure your drip pan is large enough. You don't want your pan to be full and to still have oil coming out (been there done that on a different car!)
Kent |
Oh yes, the good ol school of hard knocks!
Personally I like the K&N HP 1004 oil filter. the nut welded on the end makes it a lot easier to get the filter off.
Getting the oil filter off is rather easy. I can get it off with my hand. The problem is, the way the filter sits, as soon as you undo it, you get oil all over your hands.
Try working at Valvoline I do that all day... most times after running for quite sometime And if any body buys a pontiac sunfire and asks me to change the filter for them be suprised if you don't get shot.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
look out, I'm in one of my moods...
1992 pearl svx (given away) Custom Cold Air Intake Stage1 Shift Kit Brembo Cross-Drilled/ Slotted Rotors. Front and Rear 4.44 gears now in better hands of svxfiles |
I'm about to change my oil for the first time since getting the car. I tend to use 10w-30 in the summer, and 5w-30 in the winter, due to temperature differences. The 10w-30 is thicker, but in the summer it's much warmer, and i've had better experience that way. I typically use Quakerstate Full synthetic, in the clear bottle, for my cars. My car also has zero oil leak/burn, the oil pan is clean, as well as all surrounding areas, no crud on the under-side, so i should be able to get away with it. Over-all i'm impressed with the quality and condition of my engine, and how it holds it's fluids.
Plenty of opinions on oil out there Concerning the filter, I've noticed that in recent years - from about 05 and up - Subaru filters have been getting noticeably smaller. The filter for the WRX (which is the same as the Baja and Forester) is tiny compared to the OEM SVX and Legacy filters from the mid 90s. I wonder what the thinking is behind that? I would assume that bigger is better.
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
ASE Certified Master Automotive Technician w/L1. ASE Certified Master Medium/Heavy Truck Technician. Certified EVT (Emergency Vehicle Technician) Last edited by Beav; 07-09-2005 at 06:35 PM. Reason: wawawawaaaaaaaa |
