Old 06-02-2023, 08:39 PM
SvXit's Avatar
SvXit SvXit is offline
Member Incognito
Applied some Ammo Skin and took it out for a drive: https://photos.app.goo.gl/Y3BmwwET2x1aRsGc7
Very nice!! And here, another picture of your car, at Reading 18 (under previous ownership; taken on May 5, 2018).
SvXit
"Flossie" - 92 black over pearl LS-L (sold)
"Gorgeous George" - 98 Audi A8 (traded)
"Gorgeous Genny" - 02 Audi S8 (sold)
"Green Giant" - 00 Land Rover Disco II
"Grey Wülf" - 05 Volvo S60 R
"Silver Surfer" - 92 black over liquid silver LS-L
"9 of 7" - 97 bordeaux pearl, formerly with Earl Steele
Old 06-02-2023, 10:22 PM
LarryIII LarryIII is offline
Mike,
What is Ammo Skin & where is it available?
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 06-06-2023, 08:10 AM
SvXit's Avatar
Member Incognito
Originally Posted by LarryIII View Post
Mike,
Larry, Ammo Skin is available here:
https://ammonyc.com/
He has a fairly large YouTube channel on detailing with excellent content.
SvXit
Old 06-29-2023, 10:24 AM
Noriyasu Noriyasu is offline
Today I replaced the brake calipers and brake pads in preparation for the vehicle inspection.
It's a stock part that I've overhauled myself before
Old 11-13-2023, 10:12 PM
Mike621 Mike621 is online now
Thanks for giving Larry the link. I totally missed this!
Truth be told, my SVX could probably use a light paint correction in order to get the most from this sealant. I am going to have the right mirror repainted due to some flaking clear coat, at some point.
Recently, the SVX has had 6 new plugs and coils, transmission fluid change, and new Oregon permanent/collector tags.
In queue: Steering Rack replacement, Tbelt service & heater core.
Old 11-21-2023, 05:36 PM
ElCastigador ElCastigador is offline
2A - SVX NON-PURIST
Lightbulb Re: What have you done to your SVX (or other Subaru) today?
First time posting. I have been working on my SVX. Front suspension is my next project. Will be rebuilding the front calipers this weekend and I have the new crossdilled slotted rotors to install. Just got the new bearings pressed in and am awaiting seals to complete. If the part gets removed, then it gets new paint.
I think I have the geometry dialed in for a front set of PoleMotor coilovers with possibly only drilling the top strut tower support. May choose to machine a new aluminum plate instead, but have to wait until my steering knuckles are ready. New ball joints, OE lower control arms with bushings, MOOG links with zircs, and Energy Suspension red boots. Also add new front axles.
I am contemplating dropping the front cross member to install the cleaner one I have with a new rack that I also have. AND while down, redo the oil pan sealant. Trying to find all my leaks. The Y-Pipe has 175K miles of gooop and needs a power wash too.
Old 12-12-2023, 04:40 PM
SVX_MY_BABY's Avatar
How is this project progressing?
Peter
Old 12-15-2023, 04:44 PM
Mika Mika is offline
Been hunting for parts to reseal the engine. Just missing a couple of gaskets at this point.
Getting mentally ready to pull the engine. Sure hope it's not the cylinder liners, I'd be happy with cylinder heads or head gaskets.
Old 12-20-2023, 10:55 PM
Ambitious! let us know how it goes and share photos!
Old 12-20-2023, 11:06 PM
Tonight, I'm going to install the coolant temperature sensor thats been on my workbench for a little while now.
Old 12-25-2023, 09:05 AM
As you know, the genuine head gasket and head bolt are discontinued.
I used Cometic instead. According to my memo show that the head gasket replacement was done in 2019.
https://www.cometic.com/products/C4340-066
Old 12-27-2023, 02:50 PM
What did you end up doing for head bolts? I see OE and aftermarket out there now:
https://www.enginepartsonly.com/1995...xoC7eYQAvD_BwE set for $120
https://www.subaruoempartsoutlet.com...BoCeS0QAvD_BwE OE @ $11 ea
Old 12-27-2023, 02:54 PM
The sensor was pretty corroded. I'm glad I addressed it. Hopefully reduces the intermittent hard start.
Old 01-01-2024, 01:40 AM
I used this. I used a slightly thinner gasket, so the compression ratio was calculated to be 10.4. I polished the exhaust and intake ports and manifold. In fact, above 4500rpm the engine runs much smoother than the original.
https://www.ebay.com/itm/One-Cylinde...7/232960166185
Old 01-09-2024, 01:44 PM
Pulled the instrument cluster from my car to troubleshoot. I found that the speedometer gauge is faulty after another used unit works just fine. I am going to have the capacitors on the speedometer circuit board checked. I’d like to maintain mileage accuracy.
I have also encountered bad capacitors in my tachometer and climate control unit, in 2021 I swapped the tach to resolve, and a friend helped me test and replace some capacitors in the climate unit. I was unable to find a replacement used JDM climate control.
