SVXBot
Old 03-28-2018, 06:04 PM
Tmazzola12 Tmazzola12 is offline
More aggressive cam
Hey guys anybody know if Porsche per say has a cam that'll work with the eg33
Cheaper alternative?
96 Ls-I Polo Green - #467 -
Old 03-29-2018, 08:27 AM
Re: More aggressive cam
Absolutely Nothing from a Porsche will fit in a Subaru EG33.....
88 XT6 AWD 5-Speed
08 Impreza 2.5i 5_Speed
09 Forester X Premium
XT6 Site
Current Count of Subaru's Owned.... "61"
Old 03-29-2018, 11:47 AM
Damm so no such luck on cheaper alternatives to a more aggressive cam profile
I'm from massachusetts they don't work with their hands so much as in machining things as the older days or it's super expensive
Goal is a N/A 300-350 whp car close to stock looking as possible
Would need stand alone computer
Wrx injectors
Equal length headers
Poor mans cam options? Mainly intake
Gonna want to re seal and ring the whole motor for peace of mind
Money will be spend on that and the computer mainly
Old 03-29-2018, 11:48 AM
And doesn't a Porsche 944 tall boy oil filter fit the svx over the standard short can
Old 03-29-2018, 12:15 PM
I couldn't say on the filter, but Porsche had no involvement in the EG33, and they share no internal parts.....And I've never found Porsche part to be "in-expensive" anyway.
Any decent machine shop can build you a reground cam, if you give them the specs you want.
There have been a few member that have built EG33's, maybe one will chime in with some recommendations.
There is more activity on the Facebook site if you get on there.
88 XT6 AWD 5-Speed
XT6 Site
Old 03-30-2018, 09:10 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I have been using the 944 oil filter for years. A direct fit. Maybe false security but, the stock one is so small.
Gene and Ben
1994 SVX LSi AWD 124K - White Pearl
Old 03-31-2018, 09:01 PM
30 bucks a filter for maybe an extra half a quart of oil is worth it..I want to rig up a dry sump when I do the 5 speed swap as next summers goals
This years goal is just a healthy daily
Old 04-16-2018, 12:55 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Oil filter to fit Porsche 944 is $4.99 at Autozone. Low budget cam mod from way back was to use SVX exhaust camshaft for intake. Exhaust has 8mm lift compared with 7mm on intake. I had this for a while on my '94 emerald, but can't say that it made that much improvement. Was never dyno'ed. From personal experience can say that 300-350 whp N/A is not achievable. Young Tom got 246 whp on the emerald, and that was using about every trick in the book. Even so, idle was lopey, had to let it warm up for a while, before leaving the garage, or it would stall, and it failed emissions. But with the hammer down, it is a screamer. All of these are characteristics of high lift, long duration, big overlap camshafts. Look at my signature, below to see all of the things that were done to the engine. If you can think of anything more, let me know. I might do them.
By the way, this is not an inexpensive approach. Engine alone was probably between $20,000 - $25,000 before it was all over. Turbo is probably cheaper for more hp. Just need to get the CR down a bit. I've always wondered if there were some extra material that could be removed from the combustion chamber in the head that would drop the CR down a point or two to allow more boost.
____________________________________________
95 LSi Red, 27,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; Ď07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250į duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2006 Subaru Outback LL Bean, 160,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 04-17-2018, 01:37 PM
No. ECU chip MOD OR Stacker ignition ?
Is the HP ratting WRP. Or FLY WHEEL HP ? I also heard the ECU. Can't Handle much more than 20 extra HP
Old 04-17-2018, 02:17 PM
I think it is the MAF that can't handle much more HP
88 XT6 AWD 5-Speed
XT6 Site
Old 04-17-2018, 04:13 PM
Hydra Nemesis stand alone. No MAF. Dyno-tuned using a laptop, controlling fuel, spark, using input from the wideband O2 sensor. WHP. Use the search function and pull up the chart from my pull. Posted it 7 or 8 years ago
Old 04-17-2018, 08:19 PM
The Male brand for a tall boy 944 filter which is OEM on Porsche cost me 26.99 in Massachusetts
It is supposedly better for oil drain back on colder starts
I am way more interested in OEM tune-up factory setting condition
Re- sealing and bearings for the motor maybe upgrading and cleaning internals along the way before I even contemplate HP or Body and Paint
Car runs no engine light, has a real clean body with some fatal frame rot in the rear
SSP hooked it up with an entire rear suspension so there's no messing with frozen crap
Aside from gettin in back out there I may only mess with the exaugsht before I have real money
Old 04-17-2018, 08:24 PM
Maf upgrade would have been needed for 300whp anyways on a good stand alone
Wrx injectors should be able to accommodate that
Throttle body as well but it opens the intake question
And weather the vale train would allow it
Old 04-18-2018, 05:46 AM
Hydra Nemesis stand-alone doesnít use a MAF. Read this thread: MOD Mania>Proven Engine Enhancements>11:1 CR Race/Street Engine build
Also there was a 318 WHP EG33 build in 2.5RS coupe. I rode in it at Watkins Glen. Awesome but totally unsuited for the street. Jack Laverty built it at EFI Logics. With a Motec ECU. Go over to NASIOC and search it there. Itís gone now,Jack parted out the car. Too much money. RallyBob build the heads for it, also. He suggested that individual throttle bodies could have added another 30hp. More $. Speed donít come cheap and you canít just bolt it on.
Old 04-23-2018, 08:15 AM
Now we're talking this is interesting..so what if we add the 5 speed first out an outback or legacy? Then map it with some tweaking would it make the car more drivable
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
