Old 04-27-2012, 08:05 AM
Re: Intermittent A/C
Anyone have a leak? How did you fix it. Icingdeath suggested o rings . Anyone else have success with that? How many people have replaced compressors? Are they known to fail often?
Old 04-27-2012, 08:09 AM
mine was low when i got the car so i sucked it out replaced all the o-rings and receiver/drier (which you do any time you open the system) and it's held a charge for several years now. compressors aren't really likely to fail unless they are not run enough or run when the refrigerant level is too low.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 05-04-2012, 11:16 AM
torxxx torxxx is offline
I am currently having issues just like you are with the AC. There is a way to bypass the safety shut off for overpress/underpressure. You unplug the compressor wire and either power it or ground it, (cant remember I did that last summer) but it will turn the clutch for the AC pump on so you can run the system.
Wiggle any hose connection on the AC system. This is how I found my leaky O-rings. Even though the bolts were tight on the highside pressure line to the pump, the oring would leak if any side pressure occured on the fitting (so when I would hit the gas, the engine TQ would move everything enough that the oring would start leaking.
They sell Dye kits for AC, sometimes thats the only way to find small leaks in the systems.
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 05-04-2012, 02:28 PM
http://www.autozone.com/autozone/acc...questid=136530
Is this the kit? Still would like to know location of these 0 rings!
Old 05-04-2012, 03:24 PM
redlightningsvx's Avatar
Collision Refinishing Tech
theres 2 on the compressor where the low and high temp hoses connect, one on the driverside of the condensor, and 2 on the dryer beside the ABS.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-04-2012, 04:03 PM
processengr's Avatar
NAPA#208696 Receiver dryer comes with o rings...$16.86 perfect fit...unlike the o=ring kits...I bought a 250 pc kit of HBNR from Harbor freight, none were perfect size, cost was about $14...If you can get to a dealer, you will save money and get a perfect fit...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 05-04-2012, 08:10 PM
What gaskets am I asking for ? Are they hard to change? I never worked on an AC, looks complicated. What are the chances I do all this and find out it is the compressor? I will have to check out those spots you mention . This is all Greek to me. This AC worked perfect 3mo ago.
Old 05-20-2014, 11:22 AM
SVX_MY_BABY's Avatar
Old thread, I know.
Can anyone tell me if a condenser from 93 - 97 will fit my 92?
Peter
Old 05-20-2014, 02:42 PM
I believe they are the same from looking at my '92 and '97. The only difference is the '92 used R12. That won't matter because it will be empty anyway.
When I got my used one I blew it out with compressed air.
Old 05-20-2014, 04:10 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I would recommend a new dryer before you recharge the system. About a $150.
Gene
Gene and Ben
Old 05-20-2014, 05:46 PM
Gene
I think you added a zero, they're $15.00. I bought 2 last year.
Old 05-21-2014, 07:53 AM
Got a new drier when I had my compressor rebuilt. $18.00. My system seems to have some black film in it which is why I'm looking for a new condenser. Local shop didn't think methyl/nitrogen flush was reliable even though they do it if requested.
Peter
