Old 10-23-2011, 09:23 AM
How to manually roll down window?
Is there a way to roll down the window while the door is off the car? I want to remove the glass and motor on a junk door and I believe it has to be down for it to come out.
Old 10-23-2011, 09:35 AM
Re: How to manually roll down window?
The easiest way is to use a battery. I've used cordless drill batteries and jump packs. There are 2 wires going to the motor. + to one and - to the other will go up, reverse them and it will go down.
If you have no battery access, if you can unbolt the motor from the regulator, you can then push the window around.
Old 10-23-2011, 11:27 AM
Can use a car battery or is it safer to use a smaller one. I am assuming a 12 volt is what I should be looking for?
Old 10-23-2011, 01:04 PM
Ok, I got it. You were right the drill battery worked great.
Old 10-23-2011, 05:49 PM
Glad it worked. For reference though, a car battery will work, it's just more manageable to use a smaller battery.
Old 10-23-2011, 10:54 PM
davew833 davew833 is offline
Drill batteries are great for testing power accessories before buying them at the pull-it-yourself junkyard. Most won't let you bring in a car battery or jump pack so a drill battery is a great option.
davew833@yahoo.com
Former 6-time SVX owner
Old 10-24-2011, 05:43 AM
Subaru Alliance Subaru Alliance is offline
+1 for the drill battery idea, I've never thought of taking one to the junkyard for testing. Great idea
2003 Baja Sport
1994 SVX LS
1992 SVX LSi parted out
