Old 10-18-2011, 08:07 AM
Huskymaniac's Avatar
Uses the ignore feature
Where can I get 12V inside the car with the key out?
I would like to connect some IR LEDs to the 12V line. I need to be able to have them on when the key is out. Is there a 12V line in the car that is live when the key is out?
Tony
Old 10-18-2011, 08:18 AM
radarwhiz's Avatar
Fairmont State University
Re: Where can I get 12V inside the car with the key out?
Tap into any of the existing interior lights, ie: dome light or floor light under the dash.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 10-18-2011, 08:20 AM
hmm..Just guessing...
The clock got to be constant right? or 12v constant on the radio harness?
How about the map lights? aren't those constant just switch interrupted?
Old 10-18-2011, 08:29 AM
Offhand, the only thing that probably has power all of the time inside the car is the clock. Maybe tap off of the clock fuse under the dash?
Believe it is a light green wire w/ a red stripe.
Sure others here may have found an easier solution
Old 10-18-2011, 09:12 AM
That sounds like it should work. Hopefully it isn't too much of a PITA to get to. Thanks.
Tony
Old 10-18-2011, 03:35 PM
Hazard button always has 12v without key in the ignition.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 10-18-2011, 06:45 PM
kwren's Avatar
kwren kwren is offline
Tony, might be easier and just as good to go right out through the firewall and fuse the line as needed...
Keith
Old 10-18-2011, 08:20 PM
The internal fuse box( on the front driver side kick panel ) must have a hot side,
Old 10-18-2011, 11:19 PM
Green1995SVX's Avatar
There is a constant +12 to the stereo to maintain the presets.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-18-2011, 11:32 PM
92 SVX 92 SVX is offline
Question, does the clock and the stereo constant use full 12 volts, and at what amps? I would think just a 1.5v and a few miliamps would be sufficient for both those needs.
