Old 09-26-2011, 03:26 PM
wyldnwoody44's Avatar
wyldnwoody44 wyldnwoody44 is offline
Mechanically worthless Man : )
car lurch after shutoff
Hey guys,
Ive been experiencing a weird problem lately. Occasionally after parking and turning the ignition off, my car jumps and then kinda rocks for a few seconds. It doesn't happen when I put it in park just when shutting it off. Plus I still have that hard thud on slow turns like a hard downshift.....its really odd, the tps is set right, any ideas/suggestions?
-92 Ebony LSL, complete with all the problems
-New self paint job; charcol metallic silver
-4.44 tranny,
Nicknamed the SexVX : )
Old 09-26-2011, 04:27 PM
Re: car lurch after shutoff
Originally Posted by wyldnwoody44 View Post
Hey guys,
ripped eng mount ?
mine was starting to do some weird stuff before i parked it up for the last few years , turned out on was completely ripped through and the other one was half ripped
Old 09-26-2011, 04:41 PM
try putting a jack with a piece of wood on it under the oil pan when you shut it off. just use enough pressure to stabilize the engine and see if it changes. sounds like you could have a bad mount.
Old 09-26-2011, 05:27 PM
Hey guys,
woody that sounds like the transfer clutch is holding the trans all bound up. When you turn the key off the clutch releases, and the transmission line unwinds.
Try it with the FWD fuse inserted, see if it stops it happening.
Old 09-27-2011, 06:35 AM
Will do and update as soon as I can, if the transfer clutch is the problem then is my tranny on its way out? Or is that an easy fix
-4.44 tranny,
Old 10-08-2011, 03:56 PM
Harvey,
I put the FWD fuse in and the same problems are still present. What does this rule in/out?
-4.44 tranny,
Old 10-08-2011, 04:12 PM
Harvey,
Well that rules out the electrics as a problem.
Leaving a problem with a blockage in the C solenoid, turning the transfer valve on. A blockage in the regulator valve reducing the pilot pressure to turn the transfer valve on. The transfer valve stuck in the on position, or the clutch itself.
The rear of the box will have to come off to check which it is.
