Old 11-11-2011, 05:41 PM
Weebitob Weebitob is offline
The Kind of Casual SVXer
Send a message via AIM to Weebitob
Failed State Emissions
So my 93 didn't pass emissions this year, which is could be no surprise considering the NJ MVS folks were hitting the rev limit for over a minute. So now I have two weeks to figure out what could be the problem before it is illegal for me to drive around with it.
Besides the possibility of a faulty O2 sensor and perhaps the catalytic converter needing to be replaced (I dread that), I was wondering if maybe the ECUTune Stage One can help with emissions? The inspection report showed a HC ppm of 350 while the state minimum is 220 and CO% of 1.36 while the minimum is 1.20%.
Also, if I do buy the Stage 1, is the firmware up to date or do I also need to purchase the 2 8bit updated ROMs? In case you look at my last post and wonder what happened I ended up not getting a whole new catalytic setup and instead had someone who welded on a set of flanges on the rusted side, it seemed more reasonable to do that at the time but maybe I shall come to regret that.
Old 11-11-2011, 06:07 PM
Re: Failed State Emissions
Seems like you are just a little off . You could try replacint the flanges with this.
http://www.amazon.com/Magnaflow-9400.../dp/B000COVGA2
Others have done it
Old 11-13-2011, 07:06 PM
put a couple bottles of heet in it and it will most likely pass.
Old 12-13-2011, 09:52 AM
swpyne swpyne is offline
I couldn't get my 96 to pass the Colorado emissions either until I installed a set of magnets on my fuel lines. I know it sounds a bit like alchemy but it does work. I have had no problems passing since I installed the magnets. If you want more specifics shoot me a PM. I can take a couple photos so you can see what they look like and where they are installed.
Old 12-13-2011, 09:59 AM
i have actually seen magnets help, it was because debris from a failing fuel pump was going through the lines and restricting the injectors. ended up replacing the fuel pump a short time later and the bottom of the tank was filled with metal shavings that were probably what used to be the worn brushes. keep an eye on your pump.
Old 12-13-2011, 11:30 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
That really S****!
1995 POLO LSI 76K MILES SOLD
