Old 08-20-2010, 07:58 AM
Cam Cam is offline
Re: Motor back in, crank like it has no compression.
YES there are two sets of dots. You have found your problem. take the cams out. turn crank to 0 degrees. Both driver side keyways should face down and both passenger keyways should face up. That is what I was going to recommend you check but tom beat me to it.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 08-20-2010, 08:13 AM
Originally Posted by Crazy_pilot View Post
Alright guys, conundrum. Took the pulleys and caps off. On both sides the cam keyways are 180* off from each other (one up, one down). The little dots on the back of the right cams line up though. Are there two sets of dots?
YES!
The top, intake cam has 1 dot, 180° away from the other dot, and the bottom, exhaust cam gear has 2 dots, 180° away.
Old 08-20-2010, 08:15 AM
Originally Posted by Cam View Post
YES there are two sets of dots. You have found your problem. take the cams out. turn crank to 0 degrees. Both driver side keyways should face down and both passenger keyways should face up. That is what I was going to recommend you check but The Toms beat me to it.
Fixed it for ya.
Old 08-20-2010, 08:39 AM
Cam Cam is offline
Fixed it for ya.
What would I do without the toms? (really though, your guys advice is always welcome and very appreciated)
Cam
'92 Ls-L Dark Teal
Old 08-20-2010, 08:55 AM
alia176 alia176 is offline
Sounds like your problems are solved by the experts here!
On another note, I had the same exact issue with another overhead 24v engine and the problem was the same: no compression. Solution was to turn the exhaust cam shaft so that the dots lined up. This was on a Toyota and also had the one dots and two dots!! I wonder if this is an universal thing with DOHC engines?
Good luck.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 08-20-2010, 09:57 AM
F*** off. I went out into the shop and immediately pulled the valve cover and saw them. Right side is reset and just needs the valve cover put back, then off to the left side.
A million thanks to both Toms. And to Subaru for making this motor non-interferance. Ah well, a learning experience.
Old 08-20-2010, 02:37 PM
The pulleys are interchangeable side to side thus the 180* markings. it all comes to down cost of making the parts. This is why the intake cam is keyed to let you know how to install the cams.
Old 08-20-2010, 04:17 PM
That's what I figured. In any case, the cams are now corrected, valve covers are back on, first thing tomorrow is to torque the cam pulleys, but the t-belt on and fire it. Then I can move on to fabbing up my new pre-cat pipes, which I had intended to do today.
Old 08-21-2010, 11:36 AM
She runs!!!! The sound of an H6 running straight through the headers has never been so sweet. That's a hell of a lot of stress off.
Old 08-21-2010, 11:43 AM
YAY!!!!
Old 08-21-2010, 04:53 PM
Ask Ben what it sounds like when your lying under the car... Be sure to speak up
Old 08-21-2010, 04:59 PM
WHAT? WHAT?
