Old 05-29-2009, 03:10 PM
SVXR92 LSL's Avatar
SVXR92 LSL SVXR92 LSL is offline
Send a message via AIM to SVXR92 LSL
Transmission shifts only at high revs.
What would be the cause of this? Would repair be feasible or replacement of transmission be needed? The reason I ask is that there is a 92 pearlie for sale for very short money near me. I'm new to this vehicle (SVX) and any help would be appreciated! Thank you in advance....Still learning and feel like a bit of a.. !!
Old 05-29-2009, 03:58 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Transmission shifts only at high revs.
I think ive heard of low internal fluid pressure doing this..... have you replaced the fluid filter inside before? Im sure more ideas will be along shortly, there is also a mod having to do with the TPS that causes the trans to shift at higher RPMs as well..... possible this was done with the car prior or there is a problem with the TPS?
