Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 04-28-2009, 04:24 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Painted alternator
Well I was changing the hoses and check valve the other day and had my alternator out so I decided to clean it up a bit. I used a small wire brush on my dremel on low speed and removed all the crud off the entire thing. Then used some ceramic semi-gloss black engine paint and gave it 3-4 coats. Here's the final result.....don't mind the dirt on everything else.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-28-2009, 05:13 PM
Chuckles's Avatar
Chuckles Chuckles is offline
There is no charge for Awesome
Send a message via AIM to Chuckles
Re: Painted alternator
Looks good... Just a question though. Isn't painting the copper coil inside the Alternator bad? Kinda looks like you did that here, but it looks real nice.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
92' Subaru SVX LS-L Claret http://www.cardomain.com/ride/3214312 for the pics and stuff
Old 04-28-2009, 05:51 PM
It shouldn't have an effect on it because electricity is still flowing through the wires. I think Mike had his powdercoated and it has no effect. Thanks for the compliment.
Seth
Past subies:
Other toys:
Old 04-28-2009, 06:37 PM
Pretty sure Mike had his case taken apart and then powdercoated so therefore the copper inside is still clean with nothing on it. Not saying that painting on the copper WILL be a problem, but it could.
Old 04-28-2009, 07:03 PM
I know but I think he had the wire coated gold because it isn't coppor colored.
Seth
Past subies:
Other toys:
Old 04-28-2009, 07:56 PM
Current flows around the outside surface of a wire, not through it. All windings (even those that appear to be bare copper) have been sealed with a high temperature insulating paint before assembly)
That is why you can get water on the windings and not have them short out.
I had the windings in my high-output alternator clear-coated to appear close to stock, but many colors are used. Yours were already coated so this is just an extra (cosmetic) layer.
Old 04-28-2009, 08:06 PM
Thanks for clearing that up John, I really wasn't 100% sure on the matter but knew it could be painted.
Seth
Past subies:
Other toys:
Old 04-28-2009, 08:11 PM
I taped off the inner copper and spray painted the outer part gold.
It looks good Seth. Now you just need to do everything else.
longassname's Avatar
Just some dude.
has anyone else noticed how hard it is to get a decent alternator for our cars?
I knew better but bought one from advanced auto. It has a lifetime warranty but I had to exchange it 3 times before I got one that charged acceptably at 560 rpms.
Old 04-28-2009, 08:16 PM
mike, john (svxcess) has discussed a manufacturer who rebuilds to stock spec and above and has apparently been more than satisfied with its performance, may want to inquire further with him...
Old 04-28-2009, 08:29 PM
Yea I know. Next is the a/c compressor as I need to replace the high pressure line thrusday so I have working a/c finally. I'm just goint to do all 3 componants in front semi-gloss black power steering/alt./ a/c compressor.
Seth
Past subies:
Other toys:
Old 04-28-2009, 08:32 PM
Just some dude.
too bad you have a 94..I have a 92 line sitting around gathering dust. I put a 94 evaporator in my 92 pearly
Old 04-28-2009, 08:36 PM
I got one from work, gotta love subie employee discounts
Seth
Past subies:
Other toys:
Old 04-28-2009, 09:36 PM
Originally Posted by SVXMAN2001 View Post
mike, john (svxcess) have discussed a manufacturer who rebuilds to stock spec and above and has apparently been more than satisfied with its performance, may want to inquire further with him...
If you want a stock 95A rebuild, you can't get any better than MANIAC ELECTRIC MOTORS
Price is less than a third of a Subaru remanufactured with twice the warranty!!
Two year warranty. $138.00 outright or $78.00 with a core exchange.
They charge for shipping to you, but will send a call tag for you to return the old alternator core to them at no cost to you.
Plus, during the warranty, shipping is covered both ways by them.
For the 160A high-output unit, click HERE
Old 04-28-2009, 09:40 PM
Just some dude.
did they ever talk to you about low rpm output of the high amp alt vs the standard alt?
