Old 11-07-2007, 05:19 PM
Question alternator questions
How many amps does the stock alternator put out? I'm planning on having an alternator rebuilt and upgraded to put out more amps to help deal with my fairily large stereo. What would be a good number of amps to have it built to be putting out? The only reason I'm thinking about doing this is that the lights on my Alpine head unit dim a little when my subs hit hard sometimes and because I was told it is a good idea to upgrade the alternator. Any better ideas?
Old 11-07-2007, 06:12 PM
Stock is 95. I have a 110A I got from Napa.
Make sure your crank pulley is OEM size as a smaller one will compromise voltage levels at idle, especially with a high output alt and stereo.
110-115 is probably good if you're just getting some headlight dimmage.
Old 11-07-2007, 06:17 PM
Any further info on the 110 amp one? I'd like to replace my ailing one with something a little more substantial than stock if I can.
Old 11-07-2007, 06:19 PM
http://www.napaonline.com/masterpage...=11&SubCatId=2
Old 11-07-2007, 07:21 PM
It would appear that you are experiencing “a little” voltage drop and only “sometimes”.
In itself this does not represent any sort of problem. The only problem could be that you are unhappy with the degree of thump that you hear.
If so, your first option is to add a capacitor at the voltage supply input to your amp.
Old 11-07-2007, 07:51 PM
I installed a Rockford Fosgate digital capacitor awhile ago which helped, but my head unit still dims every once in awhile. So I figured I would take the next step. I was informed that would either be an upgraded alternator or another battery in the trunk.
Old 11-07-2007, 07:56 PM
You must be a fan of a lot of thump, bump, clunk from close to the trunk.
Old 11-07-2007, 08:04 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
The battery upgrade is probably cheaper ... although including the wire to the front of the car ???
might be the same $ as the 110amp alternator.
I'd go for the Alternator
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
