Old 08-05-2007, 07:02 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
Hood emblem
What is the best way to get the hood emblem off of the car without breaking it?
I bought the SVX emblem and would like to replace the stock one, but I do not want to break the stock one, I would like to keep it incase I want to switch back to it at some point.
1992 Subaru SVX 5spd
1998 Pontiac Firebird Formula
1999 Chevrolet Camaro SS
2009 Subaru Forester - Mileage Junky
2009 Pontiac G8 GT
2017 Ford Mustang GT 6spd
Old 08-05-2007, 07:13 PM
svx0104 svx0104 is offline
1SICKSVX
I recomend water based goof off and a piece of fishing line it will come off nicely and wont ruin the paint or the emblem i have used this method to much sucsess you can pick up a bottle of goof off at home depot or lowes for three bucks hope this helps.
Old 08-05-2007, 07:33 PM
Dental floss works just fine as well.
Old 08-05-2007, 08:05 PM
Romantt8 Romantt8 is offline
Definitely a good idea to keep the old one in tact. I found out the hard way that a previous owners respray did not go underneath the emblem. I now have an oval shaped section of original paint surrounded by raised chipping clear coat and paint.... Not pretty at all.
1992 LS-L Liquid Silver (# 7,083).
Old 08-05-2007, 08:37 PM
I unbolted the hood latch peice from the bottom of the hood. Beneath it is a hole through which you can see the prongs from the hood badge. I used a screwdriver to give one of the points a push and it popped right off. The hood latch bolt holes aren't slide type ones, so there's no worry of screwing up you hood's latchability.
Old 08-05-2007, 08:44 PM
94SubieSVX's Avatar
OOC for a while
I used a flathead screwdriver and carefully popped it off.
bLAh
Old 08-05-2007, 10:27 PM
It's Just Eric's Avatar
Missing in action
Word to the unwise...This is VERY risky. Dental floss and (wd-40, mineral spirits, or a tar remover such as goof off) will get it done nicely. That in conjunction with pushing it up from behind if necicarry is the best, safest way to keep from damaging the emblem, the paint under / around it, AND keep you drom putting dents all around your emblem from prying
R.I.P Cool Signature.
Old 08-05-2007, 10:38 PM
94SubieSVX's Avatar
OOC for a while
My emblem was worn so much that you couldn't see the subaru symbol anymore so it didn't bother me if it cracked(which it didn't BTW). I plan on shaving off the holes before I get it painted anyway.
bLAh
Old 08-05-2007, 10:46 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
I originally used an old hotel credit card type key. I was going to put an emblem on the grille instead.
Didn't realize it was on with pins ... so the card didn't work too well.
I ended up carefully prying with a paint scraper and it came off very easily.
It must have been off before as there was no glue to be found.
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 08-06-2007, 03:00 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
It comes off really easy if you warm it up a little to soften the glue. Park the car in the sun, or use a hair dryer or fan heater. You don't need to warm it too much - don't use a paint stripping gun.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-06-2007, 03:26 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I used dental floss and Goo Gone, as mentioned above.
Old 08-07-2007, 06:54 PM
Classic SVX
Thanks for all the replies. I tried it on the teal first "just incase" something was to go wrong. The emblem popped right off with just a bit of pressure.
The one on the Claret was glued down and took a little more work to get off, and the glue was a royal pain to get off, but the Claret now has a beautiful "SVX" emblem and the teal has the Clarets old Subaru emblem.
They look good!
Thanks again everyone!
2009 Pontiac G8 GT
