Old 09-17-2006, 10:19 AM
ahmed-abrar ahmed-abrar is offline
power steering pump wanted
hi, does anybody have or know where i can obtain one for my 97 model uk spec ,as my car pump is failing rapidly!
a refurb is possible but costly for me at the moment,
will pay reasonable price plus del straight away.
thanks
Old 09-18-2006, 02:29 AM
Have you tried replacing the "o" ring between the reservoir and the pump?
If this is faulty, air gets in the fluid and causes cavitation, which makes it seem like the pump is gone.
Part number is 062610110, it only costs a few pence and is easily fitted. There is a How-to on the site, find it and read it.
For the cost involved, I would try this first, what have you got to lose except a couple of hours work?
Also make sure you refill it with ATF, not power steering fluid. Service garages are always making this mistake, refilling with power steering fluid or topping up with it. If your fluid in the reservoir is brown, it is incorrect. Fluid should be pink. ATF has better heat handling capabilities.
Old 09-18-2006, 03:13 AM
thanks for the tip, but after close inspection the pump is physical stopping when put under load when the vehicle is stationary & at idle.
it does look like i need a complete item
Old 09-18-2006, 02:12 PM
Does the belt continue to turn when the pump stops? Perhaps it's something like the tensioner pulley bearing failing or the crank pulley separating?
Old 09-20-2006, 10:22 AM
supertole's Avatar
supertole supertole is offline
AWD
http://www.bbautoparts.com/
Hello, I bought it in this web for my SVX two years ago and it works fine
A1 CARDONE 21-5882 [POWER STEERING PUMP] [Power Steering Pump] w/o Reservoir; Reman. 195.54 $ plus 60$ plus minus for taxes and postage.
Regards.
October 1994 SVX
Old 09-20-2006, 12:24 PM
Question
Good to know Supertole.
It has always been maintained[well, in the USA anyway] that there are two power steering pump types available, as there are two types of power steering; one type is for rev-sensitive steering, and the other type is for speed-sensitive steering, which is on the top models.
Any of the pumps I have seen, they have always been the one type. So I am wondering if perhaps the pump proper, what the Americans call the "core", is actually the same for all types? Maybe the difference is explained by what type of sensor they have connected in the side pipes?
Does anybody know what is the case with these pumps?
Old 09-20-2006, 03:43 PM
f1svx f1svx is offline
You could be lucky
I'll check in the shed might just have one. I'll give you a shout tomorrow
Graham
Old 09-20-2006, 08:31 PM
Smile looks like problem solved
thanks to advice and help esp from WSM AL, problem was due to faulty belt causing misbehavior which has now being replaced
