Old 07-26-2005, 08:37 PM
michael's Avatar
michael michael is offline
What Potholes ???
I found Mobile 1 to be a little too thin, just my opinion though.
Wanted: Steering Wheel
Old 07-26-2005, 08:41 PM
I hate to complicate things but let us consider the worst case scenario.
The flex plate or sticky lifter issue is quite common, but don't forget other members have had problems with loose crankshafts, bad bearings, and that one guy who broke a rod.
Without a sound clip perhaps with video there is no way we are going ot be able to diagnose exactly what could be happening.
I'd get a professional to look at it if you are not confident with what you know.
Old 07-26-2005, 09:21 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Yeah I dont like it when you complicate things either
Old 07-26-2005, 09:36 PM
I'm sure you would like it even less when piston #6 smashes it's way out of the block.
Did you even look at your flexplate?
It's visible from under the car.
Mine is at least.
Old 07-27-2005, 10:25 AM
jman050's Avatar
Its a Classic!
Mine is at least.
I havent yet, but its on my list of things to do today.
Old 07-28-2005, 12:21 AM
Originally Posted by michael
What weight oil are you using? I found changing from 10w-30 to 10W-40 cleared up my ticking. Someone yell at me if that is a no-no!
Yeah i had that symptom in my previous BMW, i put 15W-40 oil, i had the ticking sound, i switched to 10W-50 the ticking was over... LIFTERS!!!
Old 07-28-2005, 08:46 PM
jman050's Avatar
Its a Classic!
well it seems that the MMO worked its magic.....unless somehow the ticking just comes back
Old 07-28-2005, 09:40 PM
glad to hear your troubles have ended
Old 07-29-2005, 06:59 PM
It might. I had the same problem.
It ticked, stopped.
Ticked, stopped.
Finally stopped after a few days.
Old 08-06-2005, 11:51 AM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
I have the same problem on and off. I've tried an engine oil cleaner, the one just before you change it (don't remember the brand, but it was one only available from the mechanic). This was done twice, now it has an additive that is supposed to quiet the lifters, but not much seems to be happening. I'm sure it is from the lifters, the RHS of the engine (looking from driver seat).
Comes and goes, doesn't seem to relate to temperature or driving time.
Previous (and used for 2 years) oil was Castrol Protec GTX 15W-40. Mineral oil.
Now I have Mobil Super S 10W-40, synthetic Blend. I'm still evaluating this one as it is the first oil change on this oil.
Mind you, the old girl sits for quite long periods as I am overseas all the time!
(Think of all the mileage I am saving....)
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 08-07-2005, 09:46 AM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Wink
I changed to Mobil 1 5W30. No ticking now.
Used to be I always thought heavier oil was better. Maybe back in the dino "old days" it was. But...the last 2 Subarus I've bought - a WRX and now a Outback H-6 - both recommended and ran fine on 5W30. So why not the SVX???
From looking at related threads, I can't find any reliable relationship between oil viscosity to the problem. And, some people switch to heavier and it stops it.
Whatever works.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 08-07-2005, 12:21 PM
Khalil's Avatar
Khalil Khalil is offline
blah blah, blah.
I have a quick question about MMO, do you have to put it in while changing the oil, or can I put some in without changing the oil (of course not over filling the pan)?
-Khalil
*1992 SVX Red. Now 100k and climbing
Tranny rebuilt @ 84k. Repaint @ 87k.
Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K.
Old 08-07-2005, 12:43 PM
The Molinator
BUMBLE....who?
Please don't complain about anywhere in the U.S.! ......until you've been to the Philippines...or any other third world country, gentlemen! HA!
[boydoIhaveastory!]
Jim
Old 08-07-2005, 02:14 PM
A flight-less flyer
Thinking of changing to synthetic next change, but I'm worried about potential leakages - I have a "damp" engine already...
Just Crusin'
Old 11-12-2006, 11:04 AM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
I have the ticking issue now also (i swear i get a new problem every 200 miles) I tryed that lucast oil stuff.....not a good idea...it got alot worse!!!(im guessing it was to thick) so i think im goin gto go get my oil changed(its cold and wet outside...im not doing it myself!) and try some 5w30 and maybe mmo like I see alot of people talking about.... my tap want to bad but it didnt change to the car warming up.... I got the tapping issue once before after the car sat for almost a year but it went away after 10 minutes of driving.... the car has 86k on it now... god with all of the problems i have with this car I feel bad for the high mileage owners!! infact it is my only car with under 120k and it is the only one im always dumping money into! ( I have 4 other cars! including a POS ford exploder)
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
