Old 07-22-2005, 10:52 AM
Jonesy
A/C and heating not working properly
I am having problems with the temperature control in my car. It seems to work sometimes, when the sunroof is open but it will only work on the auto setting. It will not adjust to the high, medium, or low settings. I am thinking it may be a resistor as the main control seems to switch (all the buttons seem to light up). The blower motor may also be the problem. If anyone has encountered this problem before please let me know what you did to fix it.
Thanks,
Jonesy
Old 07-22-2005, 12:12 PM
repeat7890
Old 07-22-2005, 12:13 PM
It could be the blower motor. Mine is currently out getting the brushes replaced.
Going from medium to high speed you should hear a relay near the motor click.
Old 07-22-2005, 12:17 PM
Jonesy
I can hear everything clicking (relays) but nothing happens. I just find it odd how it works sometimes, but not all the time.
Old 07-22-2005, 12:20 PM
Try my 2 minute fix:
Take the bottom cover off the motor but be careful as there will be a lot of dust in there.
Clean the dust off as best you can and put it back on. This will help the motor spin faster but I don't think this is a lasting solution.
Old 07-22-2005, 02:54 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Check this link for diagnostics...also ref's reapers site for further heat, a/c, and blower motor diagnostics.
Old 07-22-2005, 03:38 PM
Jonesy
excellent, I take a look through there and try to determine the source of the problem. thanks
Old 07-22-2005, 03:57 PM
Of course I could take a look at it for you when I'm passing through Calgary in a couple weeks.
Old 07-28-2005, 05:30 PM
Jonesy
that would work perfectly! I wouldnt mind seeing your SVX either. I replied to your PM too.
talk to you soon.
